Multi-Axis Turned Wood Canteen by Scotttland
Featured
  Multi-axis, or 'eccentric' wood turning is the turning of parts in two or more phases, set at different axis.  The different axis can be parallel, angular, or at 90 degrees.  In most cases, this will mean turning a piece of wood in a very lopsided way, with the center of gravity offset from the axis.  I recommend using a robust lathe for this purpose, along with a faceplate when possible, though I have seen more extreme turnings on lighter lathes than the one I am using here.
  In this project you will be making a traditional rustic Romanian-style canteen/flask/jug.  This one was made at TechShop.
  You will need:
 -A sturdy lathe with a faceplate
 -A large drill bit (around 1") and a way to turn it
 -A turning gouge chisel
 - A straight turning chisel
 -Sandpaper
 -A saw
 -Wood
 -Glue
 -Wood finish (optional)
Step 1: Axis 1
The first step is the standard woodturning process.  If you can, drill the mouth of the bottle first and use it to set the centers.  This will ensure you are starting with a concentric shape with the mouth in the exact center.  I am using a scrap of 6"x6" Douglas fir; I do not typically recommend using soft wood for multi-axis work (note the chucking around the rim), but this is just a demonstration and probably a good option for your first such project.  The first turning must be finished smooth at this step.  Sand and do whatever else to finish this surface, you will not be re-mounting it again.
Packmule says: Dec 2, 2012. 5:44 PM
I have envy of the powerMatic lathe my friend Very Very Nice!
artworker says: Feb 20, 2012. 11:00 PM
Looks like a nice potion bottle. Nice way to hollow a wood! Never thought of that.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
