loading
Step 3: Bowling-out the Interior
This step is essentially bowl-turning, except you will be turning an asymmetrical piece that will remain asymmetrical.  If your lathe has speed control, ease into it.  I find I can safely  rough-cut a piece like this at 700rpm.  Your chisel will want to wander away from the center, so make your cuts carefully and perpendicular to the surface you're cutting into.  Start from the perimeter and move in towards the center, resisting the outward force.  If you drilled the mouth deep enough, you should break-through to it.  When working with hard wood, you can leave much thinner walls than I did here.  If you have the skill and a proper square chisel, make a step in the rim of the bowl to better seat the cap later on.
hey i like the idea of the canteen, tho i have some questions, 1 is your face plate a screw in type? and do you glue on the back side also <br>(the side used for face plate) thanks Traveler
I screwed the part to the face plate for this project, though that is not the only way to mount it. And I didn't bowl-out the back side, I just turned it to be round.
I have envy of the powerMatic lathe my friend Very Very Nice!
Looks like a nice potion bottle. Nice way to hollow a wood! Never thought of that.
About This Instructable
13,000views
49favorites
License:
More by Scotttland:iPhone 5 Case, of Leather and Titanium Ye Olde Holdfast Roubo-Style Workbench
Add instructable to:
