Multi Beaded Plait Bangle - Choker/Bracelet/Ancklet
2,257
96
16
Published
Introduction: Multi Beaded Plait Bangle - Choker/Bracelet/Ancklet
About: I'm a mom of 4 and I love to craft! Anything and Everything interests me and i love to create in the process of learning.
I like having jewelry which can be adjusted so that you may wear it in different parts of your body according to your moods ;-).
This is pretty simple and can be adjusted to the colors you like very easily.
Step 1: Materials
Small beads in two colors.- Bronze and White (you could add more according to your preferences)
Craft wire small enough so that the tiny beads can go through.
Pliers.
Step 2:
Cut 15 wires the same length. If you want to use as a choker, take it extra long so that it would wrap around your neck comfortable. If you want to use this same bangle for your hands too don't take too long as it might fall off your hands. Try and get a proper balance.
Take a length of wire and make a loop in one end.
Now add white beads, and fill up till you reach your required length. Make another loop at the other end closing the wire.
Wrap around a glass and try and bend to a nice circular shape.
Make 9 White and 6 Bronze.
Step 3: Assembly
Take another wire. Make a loop and pass a bronze bead.
Now pass the loop of one bronze bangle, a spacer bead (bronze) ,white bangle , spacer bead, and so on.
I did the bangles in a pattern of bronze, 3 whites and bronze. With bronze spacer beads in between. End with a bronze spacer bead and close with a loop.
Now separate the the single bangles into 3 sections. You would notice that you would get the whites bordered with bronze.
Gently plait the beads as shown in picture. make sure that you do not entangle the bangles. 3 plaits should be enough.
Take another wire and make a loop at the end ( take an appropriate length) .
Now make sure you hold the bangles in the proper order and feed the wire through the loops with a spacer bead in between. Close off by making another loop.
There it's done!
Now you can wear it where ever you like! Your wrist? your ankle? your neck? :-) feel free to experiment !
You can do various colors. Perhaps add more bling with silver beads. It's your choice!
Please try it out and let me see your creations!
And don't forget to vote! Thank you :-)
    • Stick It! Contest
      Stick It! Contest
    • BBQ Showdown Challenge
    • Backpack Challenge
      Backpack Challenge
    16 Discussions
    Thanks! yes, seems like exams all over. It's term end and now holidays :-).
    It's the Sinhala/Tamil New Year here so a long 5 day holiday for everyone!
    Hey! you should have a contrast backround for your projects.Look! on the grass it looks much nicer than the white background.
    well I did take some of the final pictures on the grass. ..but it didn't come out well.These are obviously the best I had :-).
    For the instructions I thought to go for white background cause I've noticed in some of the photo instuctables advised to do so to avoid distraction from the main object.
    Wow....this is so versatile and beautiful Shazni :). I always wanted to say that you need more light in your pictures but this time they came up very clear and nice.
    Good job done here.
    Thanks! yes, I've noticed it too :-). This time I got myself a tripod so it's much easier to take pictures with one hand. Also usually I work during the night, hence the bad lighting. Will try somehow to get the main pictures during day in future projects :-)
    Thank you so much! It's lovely to here such lovely things at 1 in the morning ! :-)
