Fog machines are common equipment when it comes to Halloween, but they have their drawbacks. They shoot fog in only one stream, and the fog is limited to the color white. Now you will be armed with knowledge about how to create a fog spreader that has colors which you can change with the flip of a switch.
Remove these ads by
Signing UpStep 1Materials
- Fog machine.
- 2 sections of PVC pipe.
- PVC T fitting that fits your pipe
- 12 bright red LED's
- 12 bright blue LED's
- 1 SPST (single pole, single throw) switch
- 1 SPDT (single pole, double throw) switch
- Soldering supplies
- Wire (several yards)
- Hot glue and hot glue gun
- Drill with 1/2 in bit and 5 mm (or close) bit.
- Epoxy
- Cable ties
- X-acto knife
- Tape measure
- Piece of scrap wood
- Some sort of strong tape (Foil tape is recommended. This stuff is amazing)
nice job though.
I found this driver board awhile back and for the cost , I'm giving it a try. I 'm building a lightshow system for my Granddaughter for Christmas and needed a no-programing- required interface to bring it all together.
What's nice about this device is that it is also programible via serial port and Hypertext terminal if later on she would like to gain direct
control of her lighting system, so I'm also includeing a
serial interface (RS 232) card and cable in the package with a programing lesson gift card (with myself as the instructor-lol).
These two items are availible at the same website for $ 12usd.
Oh, I almost forgot, this little gem of a driver is only $15 usd+shipping! Both the driver and the serial interface are fully assembiled
and ready to go.
To supply the lighting ,I also purchased a 5 meter 5050 smd rgb strip with 300 LEDs (or 60 Leds per meter )waterproof and fully addressable,
and three 3watt ultra high intensity rgby/w modules, (to be used as wall washers) which are also compatable with these devices and can be
chained to add as many more as you would like.
While I'm waiting for this stuff to arrive from China, I'm building housings for all the different effects tI have designed into this system
I'm reworking 2 ATX computer power supplys to give the system plenty
of power and they should remain very reliable for years to come.
Now for the good news! I'm making my first instructibale as I put this project together with lots of pictures and what I hope will be clearly explained narration.
I'm hoping to finish all the editing and tweeking on that and getting it
posted before the end of Feb. 2012. If I can borrow a good camcorder from one of my friends, I'll include a video or two
of the finished project in operation.
Hope the info about the hardware will help some of you solve your problems with building your Led projects.
What follows is a link to Sure-Electronics LLc in Nanjing China and tech specs for the driver.
Good Luck everyone and happy tinkering!!
Emotec In Texas
http://www.sureelectronics.net/goods.php?id=1159
Audio Synchronized RGBW RGB LED Driver Demo Board
Brief Introduction:
DE-DD13111 is a LED driver with an audio synchronization mode that virtually
eliminates the need for real-time software processing for LED lighting effects,
especially for use with RGBY(W) LED lighting color displays (CD-001-xxx series) , but may also be used to drive LED arrays and LED strips of any length.
In audio applications,your PC, MP3 player, CD, DVD or cell phone can be used as the audio source. Connected to the driver ,which is
powered by DC12V, RGBY(W) LED lighting color displays
will dynamically display the variation of the incoming audio signal.
The audio input signal is filtered into four kinds of frequency: low, medium,
medium-high and high, with each range of frequency assigned to a specific PWM driver. Four PWM outputs respectively control one of red, green
blue and yellow LEDs. You can write commands via Hyper Terminal to
specify LED color to a corresponding frequency of your choice and adjust the gain of each frequency to change LED intensity. LED intensity can also be
controlled by duty cycle which is adjusted by the amplitude of the spectrum.
In addition, either of the two on board jacks can be used for audio signal input or output.
Definition of frequency:
Low-- 150HZ
Medium-- 600HZ
Medium-high-- 3KHZ
High-- 6KHZ
Specifications.
Supply Voltage Input Sensitivity Operating Temperature Humidity Range
Typ. 12vdc ±0.5vdc -10 to +60 degrees cel. 0-85% RH
Max. 13.7vdc +75 degrees cel.
Min. 11.5vdc -40 degrees cel.
Applications
1.Cell Phones
2.Portable MP3, CD, DVD, AAC players
3.PC, PDA's
Features:
1. Size: 78.00 (L) ×77.36 (W) ×18.70(H) ±0.2mm
2. Four PWM outputs control four color LEDs
3. Accesable via serial port and hypertext terminal to set the corresponding
relationship of colors and frequency.
4. Individual PWM gain setting can be configured 4 different ways.
5. Gain of each of four frequency bands: default 10, adjustable from 1 to 50
6. Default corresponding relationship of colors and frequency:
Y/W - low frequency
B - medium frequency
G - medium-high frequency
R - high frequency
but for parties...
Again, I don't know exactly how to engineer and create my suggestions but I bet many other Instructables members (*cough* zachninme *cough*) would be able to help you.
