3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Multi-Color LED Fog Spreader
Step 3Drilling the Pipe
Drilling the Pipe
  • last photo ←
Start with everything on one side of the T, then move to the other and repeat.
First measure the total length of the pipe. Depending on how long of a pipe you have, the distance between holes and number of holes will vary. I used 3 holes on each side with about 8 inches between each, and a 2 inch offset form the end of the pipe and the T connector. Don't make too many holes because the fog will not spread out as it should. Generally 3 is a good number per side.
Mark the holes and drill them. But remember; measure twice, cut once.
Once the holes are drilled you may have excess plastic around the hole. I believe this is caused by my drill having low power so your results may be different. Use a X-acto knife to remove the excess plastic and make the hole clean.
If, like me, you used a spade drill bit, when drilling the hole was completed, the bit punctured the back side of your pipe, cover that hole with foil tape to prevent fog from escaping.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:marc92
