3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Multi-Color LED Fog Spreader
Step 4Prepare LED's
Prepare LED\
  • last photo ←
For this step, do it once of the blue LED's and repeat it for the red LED's.
Mark and drill two 5 mm holes in the piece of scrap wood. The holes should be about 2 inches apart. This will be used as a LED soldering jig.
Take half of your LED's and separate them from the other half of the LED's. On the first half, bend the negative lead of the LED down to the right. This group of LED's will be called the "positives, because the positive lead is sticking up. For the other group, bend the positive lead down to the left. This group of LED's will be called "negatives," because the negative lead is sticking up.
Place a "positive" in the hole on the left side of your jig and a "negative" in the right hole on the jig.
Solder the bent leads to each other and repeat for the rest of the LED's.
Repeat.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:marc92
