Step 5Attaching the LED's
Cut your wire so the positive and negative wires are staggered like in the first picture. Make sure that you have enough wire so the LED's will sit with one on either side of the hole in the pipe.
The pairs of LED's will be wired in parallel. Solder the two positive wires to the positive lead of the two LED's. Then solder the two negative wires to the negative lead of the LED's.
Tape the completed LED assemblies to the pipe on top of the holes in the pipe. Make sure the LED's are pointing outward, in the same direction of the hole. Then do the same for the rest of the LED assemblies.
Once all the LED's have been soldered to the wire and taped to the pipe, hot glue them to the pipe. I only tacked the LED's to the pipe so I can remove and reuse them later if necessary.
When repeating this step for the other set of LED's, tape them to the other side of the pipe.
Repeat.
After repeating, use cable ties to hold the wires in place.
Add Comment
