Introduction: Multi Color Light Up Glowing Sword - RGB LEDs for Painting With Light.
Picture of Multi Color Light Up Glowing Sword - RGB LEDs for Painting With Light.
I just got new blades for my windshield wipers and the package instantly made me want to start sword fighting. Blinky light swords for painting with light?!?!!? YES!!!
You can create this project for:
Photography Special effects called Painting with light
Fun glowing sword for costumes
Fairy Princess Magic Wand
Stuff used:
wiper blade cover
3/8" plywood
wood glue
RGB LED tape with controller and battery - (controller lets it change colors and speed of blinking)
packing foam sheet
hockey tape
tools used:
pencil
paper
scissors
band saw
belt sander
drill press
soldering iron
heat shrink tubes
heat gun
digital camera
tripod
These are example images of the painting with light done in the first couple nights of making this project.
The photos were shot at night in low light with manual exposure times from 2 seconds to 15 seconds, the f stop was typically about f8
Lots of experimenting will give you different results. Run through the image with the lights sword moving around. Where ever the lights can be seen by the open camera, the image will have streaking colors.
Step 1: Make Your Sword
Picture of Make Your Sword
The wiper blades that inspired this project were from goodyear. The package just seemed to be really useful for much more than just selling product. Swords yes! storage of long rods and stuff... yes, but that's another project.
I did a quick sketch on a folded paper to make the hilt symmetrical and traced it out on some 3/8" plywood. The handle was just about right for one of the batteries I would be using. I then cut it out on the band saw. Quick shaping and cleanup was done on a belt sander.
The wood is pretty flimsey by itself so I made some strengtheners for the hilt area. glue these on with wood glue and clamps. (scrap wood was used to help with the clamping)
Be sure it will all fit nicely in the clear tube.
Step 2: Attach the LED Light Tape
Picture of Attach the LED Light Tape
Solder battery connecter to your LED tape controller. I was using a  3s lipo battery with Deans connectors - your power source may vary according to what is available.
I drilled a slot in the tip of the sword for the LED tape to fit through. I know this will be played with rough and the slot will help protect the LEDs from damage whenever the sword is stabbed into anything solid.
When you are happy with the length needed, peel off the backing and apply to the sword. I went right to the hilt and the tape backing was able to fold and work it's way onto the hilt strengthener.
Test to see if it works.
Step 3: Cover Lights With Foam and Tape
Picture of Cover Lights With Foam and Tape
I used 1/4" white foam that must have been packing material. I cut it into strips and glued them to the sword. The foam helps to protect and diffuse the LEDs and pad the sword a little.
I then wrapped the foam covered sword with hockey tape to bind it all together.
Be sure that the sword will still fit inside the clear tube. This will stiffen the sword and make it durable, or can be used as a scabbard instead.
I used a heat gun to soften the end of the wiper blade  tube and then folded it to match the point of the sword. I held it in place until it was cool enough to retain the new shape.
Step 4: Enjoy Your Light Up Sword!
Picture of Enjoy Your Light Up Sword!
Doing painting with light is a lot of fun and really lets you be creative.
I constructed this project at the Tech shop in Menlo Park California.
http://www.techshop.ws/
They have all the tools I needed to make this project happen.
NIMA 1383 (author)2016-04-06
00
O
great
Azzurro (author)2014-01-05
O_O the word "cool" is redefined here. RESPECT! :D
karlpinturr (author)2013-12-29
Very nice again - voted in all comps and favourited, just like your plane.
Have you seen Pixelstix (I think that's the right spelling) on Kickstarter at all? It's a similar idea (a 'stick' of these RGB LED's, used to 'paint with light'), but more --- business-like(?). I think the two formats could complement each other rather well.
Emma237 (author)2013-12-27
wow that is so cool
roballoba (author)2013-12-23
I have gotten these lights as well as other styles on www.ebay.com ... look for 12v RGB LED strips. I have also gotten similar LED strips from www.Hobbyking.com The set in this instructable had the RGB leds separated which show as seperate color striped in the photos... I have also had great success with an integrated RGB LED that will allow for more color combinations.
There are waterproof versions available as well. These will have a thick flexible covering over the LED tapes and offer more protection. Good luck with your projects and have fun!!
length (author)2013-12-23
Love this! As jonwells asked. Where can I find this light tape, controller and battery combo?
shadowtones9 is awesome (author)2013-12-22
it looks awesome
jonwells (author)2013-12-22
Great job. I would like a recommendation for the specific light tape, controller and battery. I've never used any of those materials.
laughingjungle (author)2013-12-22
This is so cool. I want to see more of the art pictures.
nerd7473 (author)2013-12-20
cool I will vote
roballoba (author)nerd74732013-12-21
sweet thanks!
nerd7473 (author)roballoba2013-12-21
you are welcome
probetox (author)2013-12-18
Voted!
Great job man
roballoba (author)probetox2013-12-21
Thanks! I appreciate your votes!!
leon33 (author)2013-12-18
It works so good
roballoba (author)leon332013-12-21
thanks a lot! glad you like it!
jessyratfink (author)2013-12-18
Such good photos! This is just fantastic.
roballoba (author)jessyratfink2013-12-18
Thanks! and it's soooo much fun to do!!
About This Instructable
31,680views
346favorites
License:
Bio: Trying to learn faster than I forget. It will be cool to make some stuff along the way.
More by roballoba:Fix a TrellisFlame Grilled Oreo Cookies - S'Mores Are Gonna Hate This One.Fix a Broken Stud / Remove a Broken Bolt
Add instructable to:
