loading
Step 4: Testing It Out
We found a small 4 switch button fro an old computer. Each one of the terminals will control one light. we also added a 9 volt battery which works great.
However we had a better idea, instead of using a small 4 switch - switch... you can use potentiometers that allow you have more control over the lighting system so if you make one of these, use potentiometers they have a way better effect :)
We placed everything on a small bread board following simple Switch circuits. i.e.
The power outlet for the light, goes to a battery positive terminal, the negative terminal goes to the switch , the other end of the switch goes to the Blue light. and so on until all the lights are connected following the same pattern.
<p>I've scavenged my broken scanner and making multicolor lamp is a great idea!<br>How many volts did you applied?</p>
About This Instructable
20,970views
30favorites
License:
Bio: We are a group of Engineers, Tinkerers, Designers, Programers, and Nerds ! ---- and Since April 2011 We also have a Cupcake Maker
More by HM-Innovations:Cupcake PushPops Super Mario Mushroom Cupcakes How to make Decorative Cupcakes
Add instructable to:
