Multi Coloured Vinyl Cutting
1,560
47
4
Posted
Introduction: Multi Coloured Vinyl Cutting
This instructable explains how to use the Silhouette Portrait vinyl cutter, to make simple, one-sided multicoloured stickers.
Step 1: Overview and Materials
The idea is to lay several layers of different coloured adhesive vinyl on top of each other, cut through them all, and then remove the unwanted layers to expose the desired colour of vinyl in that area.
You will need:
-Silhouette Portrait desktop vinyl cutter
-Computer running Silhouette Studio
-Vinyl (one large sheet, and several smaller sheets)
-Scissors
-Sharp nosed tweezers
-Scalpel
-Sticky tape
-A clean, dust free working area
Step 2: Stack Vinyl Layers
Peel the corner back from one smaller sheet
Stick the exposed corner to the backing sheet in the correct place
Use the tweezers to peel the backing paper away from behind the small sheet while evenly pressing down the new vinyl layer to minimise bubbles (if you have a dusty working area, you will get little bubbles which can not be removed)
Repeat until all of the layers are ahieved
Step 3: Trial : Find Out How Deep You Need to Cut
Unlock the blade, set it to "1", put it back into the machine and cut a "1" using the vinyl cutter.
Repeat with numbers 2 through 6.
Remove the vinyl from the machine and peel away all of the material you can.
You can see with the vinyl I used (ORACAL), setting 3 got through to the base layer, and setting 4 cut through all.
I know to use setting 3 for all of the detail, and setting 4 for the boundary box around the whole sticker.
Step 4: Cut and Peel
Cut using the setting found (3 for the features and 4 for the boundary)
Using the sharp tweezers, dig into the top layer and pinch, to peel away the top layer, repeating until the desired layer is exposed.
Each time, clean the tweezers by sticking the scrap vinyl to a piece of upturned sticky tape.
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
4 Comments
The sticker looks great! Thanks for sharing how you made it.
Nice idea to layer the vinyl up looks good :)
Thanks :) it's nice and easy isn't it?
Unfortunately, if it's stuck to glass, you can't see it from the other side.. but this (slightly tricker) method, does!: https://www.instructables.com/id/Single-Layer-Multi-Coloured-Vinyl-Cutting
