Trying to find a place to rest on the trail can be a challenge; especially when the woods are wet.
Carrying a camp chair in your pack seems like an unnecessary luxury, however, if the hiking stick you were planning on carrying anyway could serve as a lounge chair, you just might want to indulge.
This Instructable describes the steps for making a convertible walking stick with an accessory seat. At a height of 6 feet when fully assembled, the walking stick is really more of a Hiking Staff however, the 3 piece design makes it easy to transport and allows it to convert into a seat.
But there's more...
This is the first in a series of Instructables demonstrating the versatility of this Hiking Staff. Subscribe if you don't want to miss the next two sequel Instructables:
- Decorative and functional copper shod finial staff ends with storage
- Staff-top provision for an illuminating torch
Step 1: Staff Size
(3) 1” diameter hard wood dowels (each 2 feet in length). I used oak for this project.
A grip near the top of a taller staff allows it to extend well downhill while the body remains upright during a descent.
The only negative I have found with a Hiking Staff is the inevitable accusation of sheep herding or the resemblance to Moses (which happens despite the lack of beard credentials) .
Step 2: Add the Copper Connectors
(2) 3/4" diameter sweat fitting to 1/2" threaded male copper plumbing fitting
(2) 3/4" diameter sweat fitting to 1/2" threaded female copper plumbing fitting
The outer diameter of the 3/4" sweat fitting matches the 1" diameter of the wood dowel. This creates a nice flush transition at the wood to copper interface.
(Be sure to use 3/4" sweat to 1/2" threaded reducer fitting. The diameter of 3/4" sweat to 3/4" threaded fitting will be too large to fit through the ring used to assemble the seat.)
(1) Package of two part epoxy adhesive
- Brandname “JB Weld Epoxy” adhesive holds well on metal.
- Make sure to use the original JB Weld that requires 24 hours to cure.
- Do not use the quick cure (15 minute or less epoxies - including JB Weld Quick) as these
do not hold as well to metal
1: Use sand paper (or chisel, pocket knife, lath or beaver teeth) to reduce the diameter on one end of the Upper Section and Lower Section dowels to match the inside contour of the female copper fittings. The dowel ends should insert to the bottom of the threads on the female fittings.
Both ends of the Middle Section dowel should be reduced to fit the male copper fitting. This dowel should insert all the way to the end of the male cooper fittings. (The male fitting requires the dowel to have two step diameter reduction in order for the dowel to fit flush to the end of the fitting.)
Reference the last photo in this series.
2: Test fit the dowel in the copper fittings several times as you are reducing the dowel diameter. The dowel needs to press tightly into the fitting. Use a mallet to force the fittings on (be careful to not damage the threads.)
Note: The fitting will ultimately have to be removed to apply the adhesive. This is where the wrench flats on the fitting come in handy. Use them to twist off the fitting.
3: Remove the fittings and “roughen-up” the inside of the fitting with something sharp (like the bent point of a nail or a file.) The deeper the gouges / scores on the inside of the fitting the better the adhesive has something to grip onto.
4: Similarly,“roughen-up” the end of the wood dowel by making grooves to hold the adhesive.
5: Mix the adhesive per the package instructions. Protect the threads on the fitting with tape. Apply adhesive to the inside of the fittings, and the ends of the dowels. - Make sure adhesive does not get on the threads.
6: Pound the fittings on the dowel ends and clean-up any adhesive that oozes out. Again, make sure the threads are free of adhesive.
Step 3: Drill Seat Pin Holes
1. Drill a 3/16" hole 2" deep into the center of the dowels at the fittings on the Upper Section and Lower Section .
2. Drill a hole in only one end of the Middle Section.
Step 4: Add Pivot Notches
(1) 2" inner diameter welded chrome ring. (Typically found in the hardware store near the chains.)
This is the Pivot Ring (reference the last photo in this series) it holds the center of the dowel sections allowing them to flare out.
Two notches are required In the center of each dowel section to accept the Pivot Ring.
1. Make the the first notch perpendicular, straight across the dowel. (I used a file to make the notch)
2. File the second notch at a 30 degree angle.
The notches should be about 1/4" wide and 3/8" deep.
the perpendicular notch is for the initial positioning of the dowels when they are loaded into the Pivot Ring. The angled notch accommodates the splayed position of the legs when forming a tripod.
Step 5: Sew the Canvas Seat
(2) Pieces heavy canvas (approximately 14"x14")
Heavy duty Polyester thread
1: Cut two pieces of canvas into triangles (14" per side)
2: Sew the two pieces together along the three sides. Stop the sew lines about 2 inches short on each end
3: Turn the sewn together pieces of fabric inside-out through one of the openings at a corner of the triangle .
4: Fold over each edge of the triangle to a width of about 3/4 inch and sew. This will form a "sleeve" along each side of the triangle.
Step 6: Thread the Cable
Reinforcement Material:
1/8" Stainless Steel Cable (Approximately 24" in length)
(1) 1/8" Aluminum double Ferrule (reference last photo in this series)
(3) 2" long Stainless Steel Cotter Pins
1: Thread the cable through the "sleeves" in the seat fabric. The cable holds the top of the dowel sections in position preventing them from over splaying.
2: insert the ends of the cable into the ferrule and crimp. A 5lb sledge hammer worked well to compress the ferrule.
3: Open the three cotter pins and load over the cable at the tree corners of the triangle. These are the Seat Pins used to attach the seat fabric to the dowel sections.
(The open legs of the pin act like a spring to hold them in the dowel holes.)
Step 7: Assemble the Seat
Load the Upper Section, Lower Section and Middle Section through the Pivot Ring.
Make sure the ring is in the notch of each section as the next section is loaded.
Step 8: Form the Tripod
The splayed dowels will form tripod legs.
Step 9: Insert the Seat Pins
Step 10: Seat Complete
I created a logo for our Boy Scout Troop using a graphics program and printed it out on iron-on transfer paper. (this paper is readily available at any office supply store.) It bonded well to the cotton canvas fabric. (Remember that any iron-on transfer needs to be printed in reverse.)
Step 11: Seat in Action
Now if only it reclined and had a foot rest....
Below you can see the Hiking Staff Seat in conjunction with the light weight Backpacking Table described in the following Instructable: http://www.instructables.com/id/Camp-Table-for-Backpacking/
Visit Our Store »
Go Pro Today »
I thought I would throw it out to the community at large
Thanks
BenT
Regards, the Ninja of Suburbia
"ThisIsIt" -- you are also correct. I too, noticed the gap, but it was before I even left the hardware store and the guy helping me explained the same thing you did. I, however, did not think about the coupler to cover the gap. Awesome idea! Thanks a ton!
I was thinking bamboo for the poles, but that would prevent the ring keeper notches from being used. I love the Copper fittings!
I'm going camping/backpacking in a few weeks and this is PERFECT.
Great 'ible, soon my grandparents and all their hiking friends will be using these too.
So much better than just a boring old hiking staff.
(Wow, can I write 2" any more in this post??)
Hi !!
I love it! It is more than good for a farmer and a sheppard(?) like me !
I made a chair like this some years ago but it was only able to sit on it. That was it.
This is REALLY good. Thank you.
I ran into 2 little problems. First, my cable was not long enough to go around my triangle. Second, I am not able to figure out how to put 3 1" dowels into a 2" diameter ring. My kindly neighbor tried to help me with this project. After I went and got a longer cable, I'm still not able to get the 3 dowels into that 2" ring. And the only rings I could find were brassed colored steel ones that I got at Hobby Lobby. I don't trust them to hold any weitght. I still think it's a really cool idea, and I'd love to finish this project. Thanks!
Make sure you use a ring that has the ends welded together or, as you suspect, it won't hold enough weight.
Load the first dowel through the ring. Align the ring in the notch. Load the second dowel and make sure the ring is aligned in both notches. Next load the third dowel.
Per the pictures below I tipped the third dowel up to allow the flared end of the fitting to pass through the ring. (make sure the female fitting is the last one through the ring - it has a smaller flare on the end).
If you are still having trouble, try making the notches deeper in each dowel. You also can file down the flare on the female fitting so it doesn't have to be "levered" through the ring.
Hope this helps.
Post a photo when you are done. I would like to see how it turns out. Especially the cloth seat part. I am not skilled at sewing and I'd like to see what someone with sewing talent can do.
I hope Kindly Neighbor and I can finish this. What a hoot that would be. Thanks again.
is there a way to combine the funtions of all 3 staffs into one staff
and still have it be portable/easy to break down
