3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Multi-Function Walking Stick - Converts to a Chair
Wouldn't it be nice if your walking stick served double duty as a chair?  This walking stick functions just as well as a stationary resting device as well as it does as a mobility enabler.
Trying to find a place to rest on the trail can be a challenge; especially when the woods are wet.
Carrying a camp chair in your pack seems like an unnecessary luxury, however, if the hiking stick you were planning on carrying anyway could serve as a lounge chair, you just might want to indulge.
This Instructable describes the steps for making a convertible walking stick with an accessory seat.  At a height of 6 feet when fully assembled, the walking stick is really more of a Hiking Staff however, the 3 piece design makes it easy to transport and allows it to convert into a seat.
 But there's more...
This is the first in a series of Instructables demonstrating the versatility of this Hiking Staff.  Subscribe if you don't want to miss the next two sequel Instructables:
- Decorative and functional copper shod finial staff ends with storage
- Staff-top provision for an illuminating torch
Step 1Staff Size
Staff Size
Walking Stick Material:
(3) 1” diameter hard wood dowels (each 2 feet in length).  I used oak for this project.
1: Cut  (3) three dowels 24 inches long.  These will be referred to as the Upper Section, Lower Section & Middle Section
Most of the new high tech walking sticks on the market today are the short (Trek) ski pole variety. Personally, I prefer a taller staff when hiking.  For me, the trail challenge is not so much the uphill incline, as it is the descent; especially while carrying a pack.
A grip near the top of a taller staff allows it to extend well downhill while the body remains upright during a descent.
The only negative I have found with a Hiking Staff is the inevitable accusation of sheep herding or the resemblance to Moses (which happens despite the lack of beard credentials) .
84 comments
1-40 of 84next »
Apr 27, 2012. 4:59 PMjerwhite says:
I've been using this for some time now. Stays in the car. It's sturdy and comfortable enough on a long hike. Also has multiple uses or maybe even endless.
Apr 14, 2012. 11:56 AMAluminumFoilMaster says:
AWESOME!!!!!!!! I used to be a boy scout in troop 10 which is on the theodore roosevelt council but my mom didn't let me stay because of all the work in 6th grade.
Apr 8, 2012. 11:04 AMeklein1 says:
Oh my god yes.
I'm going camping/backpacking in a few weeks and this is PERFECT.
Great 'ible, soon my grandparents and all their hiking friends will be using these too.
So much better than just a boring old hiking staff.
Feb 18, 2012. 5:50 PMpro pyro says:
thanks this walking stick is going to be in a boy scout contest
Aug 14, 2011. 9:44 PMkingzilla says:
needs to glow in the dark
Aug 21, 2011. 3:40 AMfreakyqwerty says:
Yes.
Jun 19, 2011. 11:13 AMwawhosed says:
I tried a 2" ring and it wouldnt fit around all three dowels. Ideas?
Aug 12, 2011. 9:22 AMmslaynie says:
Was the 2" for the outer measurement or the inner? If it's a 2" outer diameter, it won't fit. You need the inside diameter to be 2".
(Wow, can I write 2" any more in this post??)
Aug 8, 2011. 2:11 PMjerwhite says:
Update. OK, so I got this thing together finally. I have some thoughts and changes that I made. 1. The seat. I didn't/don't find it too small for a seat used for hiking. It isn't a lounge chair. However instead of using the complicated method of the cable, cotter pins, and drilling holes, I used a sewing needle(well my wife did:)). Actually I cut my triangle to about 1" bigger then it would wind up. I purchased material adhesive and sprayed this onto the material. I then folded over a 1" edge on the whole triangle. It doesn't have to be perfect but close. Then I cut three pieces each in a triangle to match the three corners of the seat. The three pieces were also cut bigger and then folded over on the edges. This will give double support later on. Then my wife sewed the pieces onto the bottom of the seat material on two sides of each triangle. The idea once finished is you just slip each pole into the triangle of the seat bottoms. This causes the seat to stick up on the poles a little but it's still functional. 2. I still used two part epoxy but I took extra precaution. After you get everything set on the poles with the epoxy this is an easy addition. I drilled through each copper fitting perpendicular to the wooden sticks(Don't remember drill bit size). Then I used a bigger bit to bevel the edge a little. I purchased a piece of brass rod(actually my father-in-law had a piece). Cut a piece of brass a little longer then the width of the copper fitting. You might have to experiment a little with the length. Put the cut piece in the hole and hammer it over a hard surface. I used the edge of my vice. An anvil would be perfect. Also if you have a ball-peen hammer or jewelers hammer it would work better. The brass fills in the bevel and creates a head on it. This should prevent it from backing out once you hammer both sides a little.
Jul 12, 2011. 4:45 PMshadow123456 says:
AWSOME!!!!!
Jun 28, 2011. 6:41 AMDevrimm says:
Hi !!
I love it! It is more than good for a farmer and a sheppard(?) like me !
I made a chair like this some years ago but it was only able to sit on it. That was it.
This is REALLY good. Thank you.
Jun 10, 2011. 7:40 AMjerwhite says:
Would using copper all the way through instead of the wood work? Would it weigh less or more? That way you could potentially use the inside of the tube for storage.
Nov 21, 2010. 1:25 PMfacklere says:
Should the 24" cable length specification say 42"? You said to make the sides of the triangles 14", and 14x3=42.
Nov 21, 2010. 6:33 PMfacklere says:
Never mind, I didn't take into consideration the loss during sewing.
Oct 13, 2010. 5:26 PMjbrecken says:
If you traded one of the male fittings on the middle section for the female on the bottom section, you'd be able to make a short stick from just the top and bottom pieces.
Aug 19, 2010. 6:50 AMWazzupdoc says:
Troop 5 is one lucky outfit! Love all three episodes. I did a variation on the traction end. I drilled a hole to accommodate the business end of an aluminum arrow shaft. I then was able to thread in a field point for icy conditions and to get the point across ;) Great ibble
Aug 7, 2010. 4:04 PMData643 says:
The seat is too small. I weigh 70 pounds and it's too small for me.
Aug 3, 2010. 9:30 AMData643 says:
Mine works fine with the 3/4" - 3/4" pieces. I just have to insert the piece with the male ends first.
May 23, 2010. 2:27 PMjrossetti says:
The sections, when screwed together, don't screw flush; there is some threading exposed, correct?
Jun 12, 2010. 7:06 PMThisIsIt says:
That's what it looks like in all the photos I've seen, and further down this page someone else says theirs is like that too. I think as long as you pay attention when fitting the couplers to the wood you should be able to avoid that. If not, just have to file down the couplers till they mate flush, and then fit the wood.
Jun 16, 2010. 7:15 AMThisIsIt says:
Upon finally finding some of the fittings to take a look at, there is no way to get them to not have a gap when screwed together. The threads on the fittings are NPT, national pipe thread, which means they taper from smaller to larger as you thread the fitting in. The gap can not be helped... However, you can sweat a piece of 1" copper pipe on to the fitting to cover the threads that are left exposed. Make a simple pattern on it and it should look great. You can even size this cover so that when the two rods are threaded together, the flat spots on the fittings (where the wrench would go) line up with each other and look even better.
Jun 17, 2010. 6:15 PMThisIsIt says:
Correction, you can't fit 1" pipe over 3/4" threaded fittings. You can use a piece of a 1" coupler to cover the exposed threads. I would probably sweat it on to the female portion, it mates up nicely.
Jun 14, 2010. 12:15 PMducttapehamster says:
I think that a 16x16x16 triangle world work better because mine seems kinda small and hurts when you sit on it...
Mar 27, 2010. 3:18 PMLoisLynn56 says:
I ran into 2 little problems.  First, my cable was not long enough to go around my triangle.  Second, I am not able to figure out how to put 3 1" dowels into a 2" diameter ring.  My kindly neighbor tried to help me with this project.  After I went and got a longer cable, I'm still not able to get the 3 dowels into that 2" ring.  And the only rings I could find were brassed colored steel ones that I got at Hobby Lobby.  I don't trust them to hold any weitght.  I still think it's a really cool idea, and I'd love to finish this project.  Thanks!
May 20, 2010. 3:14 PMTerrapathic says:
I had similar problems, my long time hiking partner told me to just buy a Stikstool. If I can't get it to work I may buy one. I don't give up easily and I have a friend that may be able to fabricate a ring for me. I may check with Tractor Supply for a ring.
May 20, 2010. 4:10 PMLoisLynn56 says:
Funny you reply today.  Actually, my neighbor gave me back the completed thing yesterday.  He weighs 190 and it holds him.  The friend that sent me the link for the thing in the first place went to her Lowe's and got the ring with no trouble.  She lives in Everett, WA.  He put off crimping the cable because he hadn't read the instructions.  It says to hammer the cable, not the connector.  But, all is well.  I've got the thing smack dab in the middle of the living room, admiring it.  LOL.  Lynn
Mar 29, 2010. 5:10 PMLoisLynn56 says:
Thank you ever so much.  Don't we all just hate a project that gets shelved?
I hope Kindly Neighbor and I can finish this.  What a hoot that would be.  Thanks again.
Apr 14, 2010. 4:33 PMArgon27 says:
 Super Awesome! Just got me an Alps Denali aluminium frame backpack for backpacking this summer. I plan on making one of these as soon as possible! A+ :)
Jan 28, 2010. 1:16 AMDuber says:
ive noticed that you made two other staffs
is there a way to combine the funtions of all 3 staffs into one staff
and still have it be portable/easy to break down
Dec 22, 2009. 6:24 PMPastTheVoid says:
Are you camera shy?
Dec 22, 2009. 5:56 PMzascecs says:
Great idea, I could use one of these for hiking. =)
Dec 17, 2009. 7:08 PMcoops1387 says:
very cool project.  I stumbled upon the instructable and made one for my dad.  The only thing is my copper fittings don't screw all the way together.  No big deal, but it looks more sleek when you can see no threads.  Suggestions?
For the rope for the seat i bought some string from the hardware store and macrame'd a rope to go through the cotter pins and joined the two ends together by doing anothe rset of macrame over the top of both.  I also messed up and didn't read as in depth as i should and used 3/4 to 3/4 copper fittings instead of the reduced thread size you recommended.  To get around the ring not fitting over i had to dremel deeper cuts in each sections to accomodate for the larger fitting passing through the ring.
thanks for the instructable
Dec 13, 2009. 4:01 PMrallen71366 says:
 This is very beautiful, with a sweet steampunk feel. I feel another hiking staff coming upon me.
I've made a few staffs before, from red oak ("black jack oak" around here). I decorated them with copper inlay made from 12 & 14 gauge romex wire epoxied in place. The inlays acted as a ruler with foot and inch markings, but I think it could be fun to do a metric one, also. I've seen one that was set up as a balance scale: hang the object to be weighed on one end, and slide a loop up the staff until it's level. The location of the fulcrum indicates the weight (the counter-weight is the body of the staff). You have to carefully calibrate the scale, but works a treat.
I've seen others that incorporated: range/height finder, flute, led lights in the head-piece and foot probe, concealed storage or blade, sundial, compass, blowgun, martial arts weapons, etc...
Most of these were incorporated in a length of wood that was rather unwieldy, rustic, and fixed to their purpose. Much like a portrait on an unflattering canvas. You have given us a great canvas to work on, now. A modular system of staff construction that doesn't need a freaking machine shop to use. I love it!
Dec 7, 2009. 3:00 PMTim Temple says:
A three-inch knife blade could be brazed onto a 3/16" rod two inches long.  That would be a helpful addition.
Nov 24, 2009. 4:32 PMd2j5 says:
w00t thats awsome i like to make walking sticks as a hobby thanks for posting it!
Nov 20, 2009. 9:01 PMdaltonjcw says:
 is that troop 9 as in the national jamboree troop? also known as 2044 or 2017? that's my troop.
1-40 of 84next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
609
Author:hpstoutharrow
