3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Multi-Function Walking Stick II - Storage Compartment
Step 5The Point
The Point
The main feature for the bottom of the staff is the cleat-like tip that comes from the end of a plumbing Stub-out.
1.
Cut off the narrow end of the Stub-out with a hack saw as shown below.
2. Smooth the cut edge of the larger barrel portion with a file.  This piece is the Point.
(the small cut-off end is not used)
The Point should slide over the end of the 1" dowel.
3. Remove the Point and taper the end of the wood dowel to match the taper on the inside of the Point tip.
It doesn't have to be exact but, getting the dowel as close to the bottom of the Point as possible will help reinforce the tip (after all it will be taking the brunt of every step.)
There will be a little "play" between the dowl and the Point. (The diameters aren't identical) This will be addressed shortly.
4 comments
Jul 9, 2010. 11:04 AMspark master says:
-please join Yahoo groups "Stick Carving World Wide" Go to Yahoo groups join and send in a bio. Very Very cool, I found you by accident and I am very happy I did. I was looking at the water hammer arrestors the other day and thinking, now what can I do with that gizmo.....hmmmm. thanks sparkie
Jan 24, 2010. 12:57 AMstarcrafter333 says:
Where did you locate a large diameter stub out? Everywhere I have checked, they come no larger than 1/2 inch diameter at the pointed end.  This sectional hiking staff is the greatest idea and it is driving me crazy trying to find the dtub out piece. Please help.
Jan 24, 2010. 7:06 PMstarcrafter333 says:
Fantastic! Thank you! I had not looked at the third installment, stupidly thinking that I was not interested in the torch feature, but neglegting to realize that more info might be part of that tutorial. Thnak you again!  Off to the HD!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
609
Author:hpstoutharrow
