Multi Purpose USB Power Adapter
 by TechGadgets
Featured
USB - we all use it every day.
USB allows to share all kind of data on a small USB-Stick, on every PC. Even big amounts of data can be carried on an USB Hard drive. And it' s a perfekt power soure for mobile devices eg. cellphones or MP3-Players.
But soon you'll spot the first problems. You just haven't enough USB-Ports to charge all your moblie devices. Hard drives need to much power for some PC's, most stereo systems and all USB-OTG(on the go) devises. It's Impossible to charge Ipods with a normal USB charger.
I was annoyed of all these problems, so I thought about a solution. I came out with this USB-stick-sized adapter. It should help you with all your USB power problems.
Mainly it has 4 functions:
1. Charge two USB-devices at a single port, while one is still connected to your PC/ other host.
2. Charge two USB-devices with an external power supply.
3. Take power from an external power supply to be able to run USB hard drives on OTG devices, stereo systems, ...
4. Charge your Ipod (I haven't on so I can't tell you if it works). This may even help to charge your moblie phone faster, but try it at your own risk.
Make sure you read the Important Information below.
Step 1: Important Information
FIRST: I'M not resposible for any damage to you and any devices that this adapter is connected to.
Read through everything (especially read bold and underlined words/phrases) before you start. Steps in [ ] are not nesessary for some functions. You can skip these steps if you want.
For this projekt it is very importent to work exactly. Even tiny mistakes can cause big problems. Reminder that whenever you work with USB. (or do you want to blow up your mainboard / phone / anything else ?)
This isn't an USB-Hub, so dont say " the second port doesn't work for my USB-stick". The second port just offers power to charge devices.
function 3:
If you want to run a hard drive at a OTG-device (in my case it's the S2) remeber it might just accept Fat32 which limits the size of one file to 4GB.
If you can check first if your hard drive runs with just power. Simply plug it into an USB charger and watch if the LED turns on or not. If the LED does't turn on (and your hard drive doesn't make the usual sounds) function 3 might not work.
I might have mixed up meanings of a few words (like port & socket) but I'm too lazy to correct it. That's it for now. Go on.
potatokiddo says: Jul 11, 2012. 10:03 PM
Can I charge an ordinary phone with this?
TechGadgets (author) in reply to potatokiddoJul 17, 2012. 7:45 AM
As you should know usb is rated at 5V. If your phone has an equal charging voltage (read the output voltage on your p hone charger) or can be charged with an usb cable it works. However if your phone is not charged with usb, you'll need to solder yourself an adapter cable. If so take a photo and ill give detailed information later.
If it hasn't 5v it will be a lot more complex, still i'll jelp you if so.
potatokiddo says: Jul 11, 2012. 9:58 PM
So where exactly does the power come from?
TechGadgets (author) in reply to potatokiddoJul 17, 2012. 7:37 AM
The power comes from the usb plug (max. 500mA) or from an external power supply (1000-2000mA). In any case you'll need 5v power source. This can be from a batterie as well.
potatokiddo says: Jul 10, 2012. 4:28 AM
Hi! Can you please explain the power socket? In what devices can I get one? How does it produce power?
TechGadgets (author) in reply to potatokiddoJul 11, 2012. 4:15 AM
The power socket does not produce any power. Its just a connection to connect the power supply. English is not my native language, I used google translater for some words, I would recomment to do this too. In case you answer prepare to wait a week or two cause I'm on vacation and usually I havn't internet access.
XOIIO says: Apr 18, 2012. 7:32 AM
Boy, unregulated DC into an expensive device, absolutely brilliant.
TechGadgets (author) in reply to XOIIOApr 18, 2012. 7:57 AM
Hey it's regulated. Realy. Read before you post bullshit.
... I spend hours making this (If you are not a nativ English speaker everything takes more time to write) and i always tried to explain it as detailed as possibe. I have no problem if you don't understand what i mean, you can always ask if you're interessed. But if you spend just a few seconds on reading this you shouldn't write a "criticism". That's why I'm pissed.
Please read the following as well:
We have a "be nice" comment policy. Please be positive and constructive with your comments or risk being banned from our site.
XOIIO in reply to TechGadgetsApr 18, 2012. 3:12 PM
Well somebody seems to be on their period, why not read that yourself before overreacting.
And by the way, considering there is no VOLTAGE REGULATOR in your circuit/schematic, it is not regulated, wall adapters or whatever power supply you use can get power surges, so maybe look your own instructable through.
TechGadgets (author) in reply to XOIIOApr 19, 2012. 6:56 AM
I wrote:
Make sure it's voltage is 5V (min. 4,65V - max. 5,25V) on every load. To measure on differnt loads you can put a resistor between + and - ; eg. for a load of 1A you need a 5V /1A= 5Ohm .
In Germany we have a very accurate power supply system (I guess you know what I mean), but I know some contries haven't these benefits.
An extra VOLTAGE REGULATER such as the 7805 would cause a loss loss of at least 2 V and only can handle currents up to 1A. A better circuit such as the PQ30RV21 (uncommon, I know ) has just a max. dropout voltage of 0.5V and a max current of 2A but you'll need some cooling as well. You see that wouldn't be the right solution anyway.
If you have another idea, energy loss-less in common use, I'd be glad if you submit it and I'll include it into the instructable.
XOIIO in reply to TechGadgetsApr 19, 2012. 4:15 PM
Still, this site is mostly used in north american countries, and a large group of the people on this site don't understand exactly how electronics work, and without a voltage regulator would fry their devices, I've seen it in loads of comments that go "blah blah blah you made me destroy my device". Generally it's best to assume people know less that you think they do.
TechGadgets (author) in reply to XOIIOApr 20, 2012. 6:19 AM
I added the following:
"a large group of the people on this site don't understand exactly how electronics work" said XOIIO and he's maybe right. If you don't understand what is meant in the following paragraph and the reason why this projekt is nothing for you. (Serch for "regulated DC" if you still want to do this and inform yourself)
Missing knowlege can destroy your devices. I don't want to hear "blah blah blah you made me destroy my device" afterwards.
Is that ok from your point of view?
XOIIO in reply to TechGadgetsApr 20, 2012. 3:05 PM
I don't even need credit, I just like to see that everything is explained thouroughly because like I said a lot of people don't know enough to do this properly, or take for granted the fac that this instructable doesnt teachthem everything.
francisdsa says: Apr 17, 2012. 11:01 PM
how different is this workshop compared to simply using an active USB hub or a powered USB hub?
Just take a two or four port USB hub, use a 5V 1A power supply adapter and connect it to the USB hub, you can get a fully working 4-port USB charger cum USB hub whcih can be connected to the OGT or the PC and used anyway. Soldering is not everyone's game.. then getting parts and running the risk of wrong connections can be fatal to the devices... (for noobs of course)
well, the workshop is a great idea, but i still think the USB hub is a cheaper and better alternative...
your comments please...?
TechGadgets (author) in reply to francisdsaApr 18, 2012. 11:58 AM
Yes a powerd USB Hub works in these situations as well, but it's bigger and expenciver (compared to 0$ if you have all the stuff right at home). This was kind a hollyday project for me as well, you might understand the sense if your parents don't like you being at the computer all time :D.
If you're not familliar with soldering (or if you have just a rusty 20W soldering iron) go on and buy a device of your choice. The main difference is that a hub has electronics build in, which might cause errors or slow down the max. data speed.
francisdsa says: Apr 17, 2012. 11:04 PM
on the other hand, a USB port would supply 500 ma of current. if it is shared with another USB device (HDD or Flash drive) it would share the current and the charging of the phone would be terribly slow.....
What do you think?
TechGadgets (author) in reply to francisdsaApr 18, 2012. 7:17 AM
No, actually not. A USB stick drains less than 10 mA 490 will still be left for other devices. A Hard drive AND charging something would be imposseble caus it would be above 1.5A (1500mA). But iif you have a powerful external power supply (mine has 2A) it should be possible.
Btw: Most PC's have one regulator for two or even more USB ports Wich meens 2 ports have 1A in total. This way it's possible to charging something AND power a keyboard AND power a mouse with just two ports.
Did this information helped you?
Adam Manick says: Apr 17, 2012. 4:19 PM
Cool project! I can tell by your diagram though that this will not work on iPods. To do this you need resistance or power on the data pins. These are pins 2 and 3.
TechGadgets (author) in reply to Adam ManickApr 18, 2012. 7:09 AM
There's a second one bro, just for you :D. Now seriously, I'am using the simple version cause I haven't any apple devices. Step 10 explains how it should word for these.
Cheers
What do you think?
TechGadgets (author) says: Apr 17, 2012. 10:12 AM
instructables seems to have a problem with display comments to the pictures. That's not my fault and I hope it will be fixed soon.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
