3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Geodesic Dome Media Pod
Step 10Making The Doorway & Door
You will now need to make a Doorway and Door to enclose your Media-Pod, it is not 100% required to have a Door, but it helps with the sound quality as the sound will bounce off the inner door and make for a better music experience.
The Doorway is Required for strength, and helps to make the shape more solid. Start with a large 4' X 4' Sheet of Door Luan skin, 13/64" thick, this is standard and is available as "Door Skin" at Home Improvement centers.
Place one of the Hexagons onto the door skin and trace around the hexagon to get a template shape onto the door skin. Then mark lines from all 6 points to find the center.
Use a Large Compass to make a 22 3/4" circle in the center, then use a Jig Saw to cut out the shape you have just made. Sand the edges smooth, and paint the door frame whatever color your whole dome is going to be.
Now a door is in order, make two circles on some scrap plywood, 1/2" to 3/4" thick, one circle will be 22 5/8", and the other will be 23 3/4" in diameter, Cut a radius on the outer edges of each to smooth out the look a bit. Face these circles against one another in the exact centers (Use the compass center holes to locate the exact center) Radius edges facing outward, screw the discs together and use liberal glue. Place a handle on the inside center of the door (The Inside center will be the small disk) screw into place from the outside (Large Disk).
1 comment
Apr 17, 2009. 6:12 PMLunera says:
Just thinking about this, If I were to make an additional Hexagon piece, I could hinge it at the top, using one or several magnets to hold the door in place (otherwise the door might get held open by the airflow from the ventilation system.) I'm thinking this might be somewhat more portable by having the door be able to stack with the rest of the hexagons.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
18
Author:greg0594
I work for a company that makes and sells Dissolution Test Apparatus, I am an Applications Engineer, I wear about 5 hats and can do almost anything asked of me. I have learned to be very creative and ...
more »
