Step 4Attaching The Pieces Together
Now we will lay out the triangles of the Hexagon or Pentagon shape you decide to make first, BE SURE NOT TO MIX UP THE PENTAGON & HEXAGON TRIANGLES AS THEY WONT FIT TOGETHER PROPERLY & YOU WON'T FIGURE THIS OUT UNTIL THE SHAPES START LOOKING WEIRD AND WON'T GO TOGETHER AT ASSEMBLY.
REMEMBER: ALL "A" SIDES FIT ONTO "A" SIDES & "C" SIDES FIT "C" SIDES, "B" SIDES WILL ALWAYS FACE OUTWARD TO THE EDGES OF THE PENTAGON OR HEXAGON.
Start by placing 2 "A" Sides together if you are making the Pentagon shapes first, then cut a strip of reinforced paper box tape that is long enough to cover the seam.
Spray the tape with water and place upon the seam and press firmly until it holds fast. Then place another "A" side triangle along the next "A" edge and tape this seam also.
Follow the pictures and continue working until you have assembled all the parts of each Hexagon and Pentagon.
Lastly, you will also need to make:
5 Individual Half Pentagons, No template is required, just use an assembled Pentagon as a template. This is the easiest component to make and is only used along the base of the dome.
Take these 5 Half Pentagons and put them aside until the Painting or Velcro stage when you will work on them again.
comments
Add Comment
greg0594 (author)
says:
Add Comment
