Introduction: Multi Purpose Childrenchair
The purpose of this instructable is to make a multipurpose childrenschair.
The requirements where
- Durable
- Cheap
- Limited materials
- Multipurpose
- Easy to make
Step 1: Multipurpose Childrenschair
The final chair have three funtionalities
- Low chair
- High chair
- Table
Step 2: Materials
The requirements for the materials was
- Durable
- Cheap
- Limited materials
The wood needs to be durable and therefore a wood board with the thickness around 20mm was needed
I desided to use a woodboard that I had in the garage which made it cheap. My board were 120 cm x 80 cm x 2 cm
With this board I could make 2 chairs if I used it for the main parts
I found a additional board that I could use for the rest.
The board was around 50 cm x 100 cm x 2 cm
Step 3: Cutting
From the main part I cut 6 pieces that where 39,5 cm x 39,5 cm
The measurements was to ensure that I had enough board.
From the extra board I cut 2 pieces that were 39,5 cm x 37 cm
The 37 cm is because the base needs to be shorter than the sides (see later)
Step 4: Main Parts
The main part went into two sets of
2 sides
1 back
The sides needed a bit of extra and I desided to Cut a "D" which is the inital letter of my girl's name.
The cutting is for decoration and for reducing the weight.
It is also important to add the holes to the sides and remember that the chair needs two heights
Step 5: Base
The extra board were cut into 2 base boards
Step 6: Assembly
The assembly is done in the following order.
- Attach one side to the back
- Attach the other side to the back
- Attach the base to the sides
When attaching the base to the sides it important to remember that the chair should have two heights.
Step 7: Finish
When the assembly is done the corners are adjusted with a belt sander
Step 8: Final Result
The Final result show how my multipurpose chair ended up,
I hope this give you some inspiration.
