Multicoloured LED Night Light
1,598
18
Posted in TechnologyLeds
Introduction: Multicoloured LED Night Light
What did you make?
I have made a butterfly night-light. This night-light has a beautiful aqua color to it. It gives off light, but just enough, so that it’s not too dark in your room, nor is there too much light, which will disturb you in your sleep.
How did you make it?
This whole creation all started off with a simple schematic, and soon enough, I was building it hand on. I have made this night-light by using batteries, wires, a switch, LED’s, a cube picture frame, and some pictures I printed out of butterflies. It was a very simple process. I soldered the battery pack with the switch first, and then I attached the other side of the switch to another wire. This was the negative side of the power. Then I took the LED’s and soldered the negative side of the LED’s to one wire and the positive side to a separate wire. After this, I took the wire attached to the negative side of the LED’s and soldered it with the wire attached to the switch. Then, I took the wire attached to the positive side of the LED’s and attached it to the positive side of the battery pack. Then I put this circuit into the cubed picture frame, in which I had stuck on pictures of butterflies, which I had printed out, but only on 5 sides. The bottom of the frame didn’t have a picture on it, as it would show anyways. And there it was! A perfectly working night-light!
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    2 Comments
    Thank you very much!, my young daughter is going to love her new night light.
    It looks simple to make, but you will get more hits here if you post pictures of the entire process.
    Thanks for the input! I'm glad you liked it :) I would've posted step by step pictures, but unfortunately i didn't have any! Sorry! But i'll try and post step by step instruction ASAP :)
