Step 2Measure, cut, measure cut
Next, measure accurately an interval of 6 and 3/8 inches. This is VERY important. I took a small piece of medium density fiber board and drilled two holes VERY CAREFULLY to be exactly that distance apart. Then, I took a hole punch and a hammer and pounded small dimples into the soft aluminum at this interval all across the length of the angle stock. Do this for each of 13 of the angle stock pieces. This means more than 160 dimples exactly the same distance apart.
The reason they must be so carefully measured is that the mirrors are all 6 inches square. The machine screws are 3/8 inches wide. This means you will have space for one mirror, one bolt, one mirror, one bolt, etc.
Add Comment
