3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Multifunction Digital Thermometer
Step 2Start Building
Start Building
For this step, use the attached schematic (word or AutoCAD) to build the circuit. I always find it helpful to first build it on a solderless breadboard. This makes it easy to fix any problems that arise before you want to pull your hair out :)
Before you start soldering it is probably best to first cut the breadboard to the final size and arrange all of the larger parts on the board (as seen in the 2nd image below). Don't forget to allow room for the buttons above the board and a power button off to the side.
It should be noted that in the schematic that R5 is a comparison resistor for the thermistor, and it might be included in your thermistor, so you should check your data sheet for how to implement your specific thermistor.
5 comments
Feb 2, 2010. 12:14 PM007chrisac6 says:
Can i get an exact parts list? Im buying from Sparkfun. For example, I wanted to know the exact thermistor i need. Is it a10k thermistor or a LM series temperature sensor?
May 26, 2008. 6:10 PMgunterhausfrau says:
another noob question. The comparison resistor, if I have a 10k thermistor would that imply at 10k comparison resistor? I have the datasheet, but I guess I'm being dim. Thanks for the information.
Dec 5, 2007. 9:32 PMklim142002 says:
Out of curiosity, what is the range on your variable resistor? I don't have that equilizer and I have some pots laying around.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
98
Author:J_Hodgie
Currently doing masters in Mechatronics Engineering, but still create in my spare time
