Multimeter Clock
21,021
180
17
Posted in TechnologyKits
Introduction: Multimeter Clock
About: You can see my blog here: http://hackedgadgets.com and my personal site here: http://alan-parekh.com
The Multimeter Clock consists of three multimeters, the first meter displays hours, the second displays minutes and the last displays seconds. A 16F628A PIC microcontroller keeps track of time and outputs a calculated current to each meter to display the current time.
Get your own Multimeter Clock Kit here.
See Multimeter Clock project page here.
Step 1: How It Works
The user enters the time by pressing three time adjust buttons. The first button increments the hours, the second button increments the minutes and the third button resets the seconds. Once the time has been entered the microcontroller will keep track of time from there. An interrupt fires every 10th of a second to increment a 10th second counter. Another routine checks to see if we have at least one full second of time, if we do the current time is incremented by a second.
The microcontroller has a separate output for each of the three meters. The meters are all in 0.5 DCmA mode, the negative lead of each meter is grounded and the positive leads are connected to a microcontroller output via a current limiting resistor. The resistor in this case is a 4.7K however this can be adjusted depending on the meter current scale available. Keep in mind that the PIC can deliver a maximum of 25mA to each meter so a meter with a lowest setting above 25mA would not work without additional circuitry.
Step 2: Building the Clock Circuit
The clock kit shown below can be purchased here.
Since the clock controller is built onto a perf board you have lots of flexibility on layout. Construct the circuit according to the schematic diagram. The PIC Microcontroller will need to be programmed with the Multimeter Clock firmware using a PIC chip programmer. When powered up the blue LED will give you a visual indication that things are working, during the power up phase the LED will light steady and as soon as the clock is running it will flash on for one second and off for one second.
The firmware was written in PICBasic Pro so you will need that language if you wish to make changes to the existing functionality. There is still about 20% of the 2K PIC code space still available so there is lots of space for some hacking.
The meter faces of the multimeters will need to be updated to show time scales. I used a program called MeterBasic by Tonne Software. To make a new meter face all you need to do is enter the measurements of the meter face, the name for the meter and scale information. In the end you have a perfect matching scale for your meter. You can download the Hour, Minute and Second faces that I created for this clock here.
Here are the parts you will need.
1 X Pre-programmed 16F628 chip.
1 X 18 pin Chip Socket
1 X 2X3 inch perfboard Circuit Board
1 X 2 position Terminal Block
5X 1N4401 Diode
1 X 100uF 12V Filter Capacitor
1 X 47uF 5V Filter Capacitor
1 X .01uF 5V Decouple Capacitor
2 X 22 pF Crystal Oscillator Capacitor
1 X LM7805 5V Regulator
1 X 20 mHz Crystal Oscillator
4 X 4.7K Ohm Resistor
1 X 1K Ohm Resistors
3 X Tactile Button
2 X 0.1 inch pin header (2 position)
2 X 0.1 inch shorting jumper
1 X Blue LED
1 X 9 to 12 Volts DC Power Supply
3 X Analog type Multimeters, preferably with a 0.5mA setting
Step 3: Clock Schematic
Here is the schematic for the Multimeter Clock
Step 4: Building the Clock Housing
To see more information about the V90 CNC machine that was used to build the housing have a look here.
The case was created using multiple layers of 1/2 inch MDF. There’s a front piece that has the actual Simpson 260 multimeter details v-carved into it. This is followed by 4 center spacer pieces and finally a back piece that has the hanging teardrop cutout.
The front piece was primed and painted with Krylon black paint before getting the details routed into it. All the other pieces were just routed in the CNC machine from raw MDF. I could have saved lots of wood if I built the sections from two pieces since the large center space in my design is wasted space but I decided to do it this way so that there will be no joints in the spacer pieces.
The black painted surface of the meter face was covered with contact paper then the details which will eventually be white were v-carved through the contact paper into the MDF. This provides a way of easily painting the fine white details using a spray gun.
Step 5: How to Use the Multimeter Clock
When the clock is first powered up the PWM outputs will default to about 50% of max output. You will first need to adjust the scale of all three meters. This is done by inserting the jumper across the scale adjust pin header. In this mode only the meter being adjusted will be powered.
* The first button (also used to advance the hours when in clock mode) is used to select which meter is to be adjusted.
* The second button (also used to advance the minutes when in clock mode) is used to decrease the full scale setting of the powered meter.
* The third button (also used to reset the seconds when in clock mode) is used to increase the full scale setting of the powered meter.
The goal here is to move all three meters to exactly full scale. When complete remove the scale adjust jumper to return to normal clock mode, at this time the settings will be saved to non-volatile memory.
The time will also need to be set. The time is adjusted using the three buttons.
* The hour button increments the current time by one hour.
* The minute button increments the current time by one minute.
* The second button resets the seconds.
  • Casting Contest
    Casting Contest
  • Microcontroller Contest
  • Make it Move Contest
17 Comments
FREAKEN AWESOME!
This is a fantastic project nice job :)
Q: why are you using two chip sockets?(see step 2 photos)
Great idea - I'm going to give this one a go as well..
I second in asking what software was used to draw up the schematic..
What software did you use to draw this schematic?
Owww, wonderful idea, great build! Thumbs up!
Hey, Excuse the noobish question, but your setting is .5 mA, so the max, when it's set on it, is .5 mA showing on the scale?
I have access to ammeters that have a non-changible scale that goes to 20 mA, can the kit run this?
LOL, I never noticed that before. I am thinking that the 2nd and 3rd are SunMa knockoffs. :)
this is too cool
LOL. I never noticed that before! That represents the quality of these meters I got, I should have spent more money on them. :)
I have one just like it except the colors around the dial are white, green, and red. Also, mine says MODEL instead of Sun(W/M)A, but it does say "YX-1000A" on it...
Thanks for the comment. Glad you liked it.
That's a pretty cool device, I'm sure the steampunk sorts would love to make a version of it somehow, but as it is, I like it... :)
