Introduction: Multimeter Upgrade on Li-ion Battery With Charging From USB
Picture of Multimeter Upgrade on Li-ion Battery With Charging From USB
How do i upgrade a multimeter
Step 1: All the Things You Need
Picture of All the Things You Need
  • Li-ion battery. 18650:
http://ali.pub/22bdhq or http://ali.pub/22bdjo . Other sizes: http://ali.pub/22bdmz or http://ali.pub/22bdnk
Step 2: If You Use a Charging Board With Protection, Use This Picture.
Picture of If You Use a Charging Board With Protection, Use This Picture.
Step 3: Without Protection Will Look Like This.
Picture of Without Protection Will Look Like This.
Step 4:
Picture of
Now you can throw away the 9-volt battery.
GayatriA3 (author)2017-12-03
if we try to use 2 bms in series for some specifications, then how do i make connections?
18650Factor (author)GayatriA32017-12-05
I don't understand you
rcs-al (author)2017-11-28
How much current does the dc-dc converter drain on idle when the multimeter is off?
18650Factor (author)rcs-al2017-11-28
close to 0 ,my multimeter could not measure it. If you worried about it, you can put the switch in the circuit break
About This Instructable
1,436views
28favorites
License:
Bio: just do it yourself
More by 18650Factor:Multimeter Upgrade on Li-ion Battery With Charging From USBThe Simplest Mendocino Motor  Which Is Made of Expanded PolystyreneWhat to Do If Charger Doesn't See 18650 Li-ion Battery
Add instructable to:
