Multimeter Probe From a Pen
Introduction: Multimeter Probe From a Pen
My multimeter probe died and I made a new one out of an old pen. Here's how I did it.
Step 1:
Search for a (not working) pen and rip it apart.
Step 2:
Scavenge the case and the metal tip. Metal tip isn't really neccesary, you can replace it with glue.
Step 3:
Make a hole in the rear end of pen's casing (sharp scissors are perfect for it) and run a wire through it. (I was dumb enough to do it later, incredible pain in the... you get the idea)
Step 4:
Get something that's pointy and made out of metal (like a nail or a screw) and some wire. When choosing a wire, make sure it's flexible enough for multimeter use AND is good for using the voltages you plan on measuring. My wire is 300V, which is just a little more than what I ever measure.
Wrap the wire around the pointy-metal-thingy (in my case, screw).
After that I used some good-old brute force to drive the screw into the pen's tip. It stuck there so well I didn't need to use any glue and I'm certain it won't budge.
Step 5:
Screw the tip back on and solder on some kind of a plug to attach it to your multimeter, unless you own a silly multimeter like I do, which uses no plugs on probes. They're directly soldered on.
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    Be very careful with this homemade probe - especially around high voltages. Many plastics are not suitable for insulation, and the voltage can arc over. I read about this many years ago in an electronics magazine. This should be fine for low voltages, but be very cautious!
    hey thanks , my multimeter probe failed & this is just perfect to replace it
