Multiple Blinking LED on the Arduino
206,629
40
44
Posted
Introduction: Multiple Blinking LED on the Arduino
In this tutorial I will show you how to make multiple LEDs blink with Arduino.  You will need three LEDs, jumper wires, breadboard, and Arduino.
Step 1: Program the Arduino
Now you will need to paste the following code into the Arduino software and upload it to the Arduino.
int led = 13;
int led2 = 12;
int led3 = 11;
// the setup routine runs once when you press reset:
void setup() {
  // initialize the digital pin as an output.
  pinMode(led, OUTPUT);
  pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
// the loop routine runs over and over again forever:
void loop() {
  digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(100);               // wait for a second
  digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
  delay(100);
  {digitalWrite(led2, HIGH);
delay(100);
digitalWrite(led2, LOW);
delay(100);}
{digitalWrite(led3, HIGH);
delay(100);
digitalWrite(led3, LOW);
delay(100);}// wait for a second
Step 2: Connecting GND
First connect a jumper wire from GND to the negative rail on the breadboard.
Step 3: Connecting the LEDs.
Then plug in the other jumper wires like this:
First, plug a wire from 13 on the Arduino to the top row on the breadboard.
Next, plug a wire from 12 on the Arduino to the top row on the breadboard.
Then plug a wire from 11 on the Arduino to the top row on the breadboard.
Space these out well. Use the picture to help you.
Now connect a wire going from the negative rail to the right of the other wires on the breadboard.
Lastly, put the longer leg of the Led (+) under the wire that goes to the Arduino. The shorter leg of the LED goes under the port that connects to the negative rail.
Step 4: Video of It Working
7 People Made This Project!
  • Spotless Contest
    Spotless Contest
  • Science of Cooking
    Science of Cooking
  • Microcontroller Contest
only 2 leds lite with me
30 Comments
What to do to turn on 4 leds?
you missed a semi colon on line 4, that's why you have an error.
how can I make two lights blink at the same time?
By the way you can also do it in a much simpler manner using delay().
//turns on leds 3 and 4 for 500 millisec
digitalWrite(3, HIGH);
digitalWrite(4, HIGH);
delay(500);
//turns off leds 3 and 4 for 500 millisec
digitalWrite(3, LOW);
digitalWrite(4, LOW);
delay(500);
for this you will need to multitask. Look into the millis() function.
Search: aduino multitasking to learn more
here's the code:
class Flasher
// Class Member Variables
// These are initialized at startup
int ledPin; // the number of the LED pin
long OnTime; // milliseconds of on-time
long OffTime; // milliseconds of off-time
// These maintain the current state
int ledState; // ledState used to set the LED
unsigned long previousMillis; // will store last time LED was updated
// Constructor - creates a Flasher
// and initializes the member variables and state
public:
Flasher(int pin, long on, long off)
ledPin = pin;
pinMode(ledPin, OUTPUT);
OnTime = on;
OffTime = off;
ledState = LOW;
previousMillis = 0;
void Update()
// check to see if it's time to change the state of the LED
unsigned long currentMillis = millis();
if((ledState == HIGH) && (currentMillis - previousMillis >= OnTime))
ledState = LOW; // Turn it off
previousMillis = currentMillis; // Remember the time
digitalWrite(ledPin, ledState); // Update the actual LED
else if ((ledState == LOW) && (currentMillis - previousMillis >= OffTime))
ledState = HIGH; // turn it on
Flasher led1(12, 350, 350);
Flasher led2(13, 350, 350);
void setup()
void loop()
led1.Update();
led2.Update();
taken from: https://learn.adafruit.com/multi-tasking-the-arduino-part-1/a-classy-solution
far more elegant
int led3 = 3;
int led4 = 4;
int led5 = 5;
void setup() {
pinMode(led4, OUTPUT);
pinMode(led5, OUTPUT);
void loop() {
for(int counter =3;counter<=6;counter++){
digitalWrite("led"+counter, HIGH);
delay(100);
digitalWrite("led"+counter, LOW);
delay(100);
