Introduction: Multiple Frame Card
Picture of Multiple Frame Card
This is a simple way to make interesting card easily.
Supplies:
  • Silhouette Cameo
  • Black Paper
  • White 4 x 5.5 Card (I got mine in a pack from Michaels that came with an equal number of envelopes)
  • Glue or Sticky Squares
You can download the attached Silhouette file or you can create your own design.
Creating the Image:
  1. To create your own design, first draw a rectangle that is the size of the front of your card.  Mine was 4 inches by 5.5 inches.
  2. Choose a shape.  I chose the "frame" from the library.  This image had two lines to it, so I ungrouped the image and deleted point by point one of the frame, leaving me with one image.
  3. Make the image so each edge is about 1/4 of in inch from each edge of the rectangle.
  4. Simply copy and paste placing each image about 1/4 an inch in from the previous image.
  5. I created the image 5 times which is perfect if you want to use the outside rectangle.  If you do not want to use the rectangle frame, repeat the image 6 times.
  6. Make sure all of the lines are cut lines and sent it to the silhouette.
Assembling the Card:
Now you just have to simply tape or past your frames on your card.  Use every other one so you have white spaces showing in between.  I showed how you can use all of the pieces to make two cards easily.  Now you can leave it as is or write a little message in the middle!
Done!
Crafty Cathy (author)2012-05-28
Love it!
About This Instructable
517views
5favorites
License:
Bio: I am powered by sugar and rainbows! For realz!
More by Penolopy Bulnick:3D Printed Creeper Christmas Tree3D Printed Minecraft Snowflake OrnamentsJack Skellington Spider Snowflake Ornament
Add instructable to:
