3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Multiple Guitar Stand
I saw some Guitar stand made out of PVC here, and since I salvaged several pieces of wood from some ikea furniture that i found on the streets I made mine with them.
Step 1Layout and Materials
The idea is pretty straight forward, as you can see in the pic. the dimensions are standard, 36' long, 16" deep and 28" high, the hight of the horizontal bar (for support of the neck) is around 26" from the top of the piece @ the bottom , and the distance between the two bottom pieces (where the body of the guitar goes) is around 12". you can try with the guitars to get a better configuration.
Materials.
I use 3 pieces of 1 1/2" x 1 1/2" by 36" for the bottom pieces and the horizontal top.
2 pieces 1/2" x 1 1/2" by 28" for the Vertical sides and some 2 planks of 1/4" x 2 1/2" x 16". All salvaged from some ikea bed that i found in the street.
The screws (8) are Allen Screws for wood ( the ones that came with bed, the Ikea ones), but some drywalls can do it too.
For the pieces that hold the guitars in place (or separators) I use wine corks and some drywall screws.
51 comments
1-40 of 51next »
Jan 24, 2012. 4:02 PMfreeza36 says:
heres mine. I made my own instructable though....
Jan 24, 2012. 7:59 PMfreeza36 says:
Thanks. You too
Jan 1, 2008. 2:40 PMDeadpunk says:
I originally saw the pvc version of this but the section of pvc I salvaged was to skinny to make to make the stand to be structurally sound and then I saw your instructable and remembered I had a bunch of spare wood out in the shed so I went out and grabbed a few pieces and got to work my dad let me use a bunch of old junk towels for padding and this is what came of it not quite as nice as yours but it works and now not only do I have a place for all my fender acoustic, OscarSchmidt by Washburn OB44 bass, and the latest addittion an Aria Pro2 Sl-DX-3 but when my band mates come over they also have a place to put there's as well :)
Jan 18, 2012. 7:07 PMfreeza36 says:
how far off of the ground is the part that the necks fit in to?
Feb 7, 2008. 8:21 AMArron says:
the towels covering it looks pretty sloppy, you can buy really cheap Foam at Hope Depot that would probably work, and work a lot better. Its by all the PVC. its only like $1.97 for four 32" pieces
Feb 7, 2008. 1:35 PMDeadpunk says:
i acutaly like the looke of the towels personaly and they do there job very well. And the towels are wraped around it in a good couple of times just to make sure everything was good and safe. But the main point of this for me was to use completely recycled products so to go out and but foam would defeat the pourpes of that.
May 11, 2008. 8:03 AMDeadpunk says:
buy*
Jan 26, 2011. 4:59 AMgoose04 says:
I finished making my own multiple guitar stand today. I used left over jarrah deck wood we had lying around, some tasmanian oak a friend gave me, and also thick wooden dowels wrapped in insulating foam stuff. Then i finished it off with a coat of oil. I love how it turned out! It holds 5 guitars. In the pictures i also have my cigar box ukulele i made hanging from one of the holders :p
how far off of the ground is the part that supports the neck(s)?
Oct 25, 2011. 9:00 PMkirkasaurus says:
Mine turned out just how I wanted. It used to be an uncomfortable futon couch sorta thing. The acoustic and gretsch kinda take up two spaces but there's still space for two more guitars.
Jan 18, 2012. 7:06 PMfreeza36 says:
how far off of the ground it the neck supporting part?
how far off the ground is the support for the neck?
Sep 2, 2010. 4:10 AMms.moth says:
I made this yesterday! I totally nicked your idea!! It holds my 7 guitars- i'm not letting myself buy any more! I added centre supports so the wood doesn't 'belly' under the weight. I didn't use corks- i used a wooden broom shank which i cut up into 8 pieces - i was planning to cover the pegs with foam/ or perhaps felt but i think i wont bother now... My smallest guitar is a 1/2 sized and i also have 3/4 and 4/4 so the height and width was worked out so the stand would hold them all. I'm really happy with the end result!
Jan 18, 2012. 4:37 PMfreeza36 says:
good luck with that. I told myself that I wouldnt buy anymore 2 guitars ago
Sep 2, 2010. 4:12 AMms.moth says:
I forgot to add- the whole thing cost about £8 to make, not including the black enamel paint which i already had.
Dec 17, 2009. 8:58 PMeddie1261 says:
I made one similar to this that holds 8 guitars and for "padding" I bought some foam insulation that you wrap around copper pipe to keep it from freezing. It comes slit to fit around the pipes and you can staple the foam on so the guitar bodies have foam to rest on. I also put foam where the necks hit the upper crosspiece. Rather than corks my separators are 3 inch piece of dowel. I drilled holes with a paddle bit and glued them in. Then I drilled into them from behind and drove a screw in.
Jan 9, 2012. 5:13 PMfreeza36 says:
what is the seconed to last guitar on the left?
Jan 9, 2012. 6:07 PMeddie1261 says:
Epiphone Dot Special
Jan 9, 2012. 6:09 PMfreeza36 says:
it looked like a cheap dean that I have
Apr 1, 2010. 3:11 PMskipernicus says:
 Thats exactly what I was gonna say!
Dec 17, 2009. 9:03 PMeddie1261 says:
Side view
Jan 9, 2012. 5:11 PMfreeza36 says:
ok, now i have 5. (addiction?) anyway, what guitars do you have?
Nov 23, 2011. 7:01 PMfreeza36 says:
I have 3 (soon to be 4) guiars, and this is perfect. I am going to have to build one
Oct 30, 2007. 7:18 PMold_bass_masta says:
Careful with the wood, i made one and it put scratches on ma SG
Nov 23, 2011. 6:59 PMfreeza36 says:
You scratched an sg? dang...
Sep 12, 2011. 9:20 PMN3M0H45 says:
I like the nylon there in the front. I've got one similar to it, but old and scratched up
:[ Anyways, in case anyone ever wonders, there's nothin' better for rocking with an acoustic than a classical guitar with Folk Singer strings tuned to drop Db. Play RED's 'Breathe Into Me'. See what I mean? Steel just doesn't sound as hardcore.
Great ''ible!! Thanks.
Feb 2, 2009. 4:08 PMthebeef2 says:
nice! i just made one based off of your pictures. i am only 13 and this is AWESOME!!! i just used some scraps lying around the garage. oh, by the way, is that a Les Paul? I got one of those.
May 1, 2011. 11:42 AMnstermn says:
It looks like a Gibson ES-335 to me. B.B. King plays one named "Lucile"
http://bit.ly/kKTCsZ
Oct 27, 2010. 9:41 AM!revenge! says:
isn't it better if you put some kind of fabric around the wood were the guitar needs to be supported? because if i'd build this i'd be affraid that there would come scratches after a while
Jul 11, 2009. 5:23 AMgtrgy says:
how far apart are the corks on the top row? thanks, gtrgy
Nov 1, 2009. 12:28 PMguitarfan says:
 i think it depends on how many guitas you have you can try 2 or 3 inches
Nov 8, 2009. 9:25 AMgtrgy says:
thanks i made one of a little different design. for the top beam, i cut out almost field hockey stick blade shapes for the necks to sit into. The rest of the design was the same as yours
Nov 2, 2009. 4:50 PMJAZ97 says:
i did the same thing exept i had a back and side panels on mine and the back had a design of old bricks with graffiti spelling my name i would show you but it broke when i was moving ( reallly mad) ill try to build another one and show how to do that.
Aug 5, 2009. 1:15 AMbradley13 says:
Great idea, just made one. Thanks
May 16, 2009. 5:22 AMiDexter says:
what is the guitar on your very right of your wooden stand, i mean like model number
Jul 25, 2009. 7:46 AMAlaskaMan09 says:
It appears very similar to the Gibson Trini Lopez made in the late '60s. Originals are highly sought after, and the Gibson Custom Shop is now creating replicas to the tune of $3,500.
Jun 7, 2009. 7:38 PMrkbot says:
Looks like one of the Bruno Ventura guitars... I have a few of them, they were not expensive then, but now after 40 years of aging, mine sound WOW! The Ventura guitars had several different head stock styles but they were all marginal copys of American made big namers I had one when I was a kid & have several around here with all of the other axes I own.
1-40 of 51next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
66
Author:arte.sano
