Introduction: Multiplexing Four 7-segment Displays Using Shift Registers Arduino
Picture of Multiplexing Four 7-segment Displays Using Shift Registers Arduino
Hallo Every one
I designed a simple way to multiplex four 7-Segment displays using Shift Registers and an Arduino
Let us multiplex the 7 segment display
Step 1: Step-1 : Let's Design
Picture of Step-1 : Let's Design
Take four 7-segment displays and solder them on a PCB in a side by side manner.
A cathode or anode display can be used. This design is for an anode display.
Combine the 7 pins (pin-a to pin-g) and the dot pin of all the four displays.
Take four BC548 NPN transistors
connect each transistor emitter to each anode of 7 segment display
Combine all collector pins together it is for power supply +5v
then we have connect base of transistors and a,b,c,d,e,f,g,dot pins to shift-registers
go to next step
Step 2: Connecting to ShiftRegisters
Picture of Connecting to ShiftRegisters
Take two 74HC595 shift Registers
connect them to form 16 bit shift register by connecting serial pin of first shift register to data pin of second shift register
Combine latch pins to form single , like wise combine clock pins to form single one
Connect enable (active low)pin to ground pin on both register
connect master reset pin(active Low)pin to Vcc in on both registers
this connection form a 16 bit shift register
now connect the a,b,c,d,e,f,g,dot pins of LED to Q0,Q1,Q2,Q3,Q4,Q5,Q6,Q7 pins of first shift register
Now connect Base of transistors ,First LED Transistor Base Pin to second shift register Q0 pin , second Base of transistor to Q1, third to Q2, fourth to Q3
Now the set up is completed Next coding
Step 3: Coding
Picture of Coding
To display numbers on 7segment we have pass +5v or connect to 0v to on each segment
we have 7 segments a,b,c,d,e,f,g according to diagram
to display 0,9 numbers some segments make them to on , some off
Table
Number Byte_to_display_7sgment(a-g) Decimal_number
0 0b0000001 1
1 0b1001111 79
2 0b0110110 18
3 0b0000110 6
4 0b1001100 76
5 0b0100100 36
6 0b0100000 32
7 0b0001111 15
8 0b0000000 0
9 0b0001100 12
above is byte and decimal code to display the numbers in 7segments
we have shift this byte to first shift register ,because we connect the first shift register parallel pins to LED's a,b,c,d,e,f,g,dot pins
Next
we connected the LED on circuit (transistor Bases) to second shift register
for make first led on we have to shift
00000001 into second shift-register
00000010 for Second LED on
00000100 for third one
00001000 for fourth one
In this design we connect first and second shift-registers each other
so we first shift the position byte first and the value next the potion byte will move to the second shift register by using serial out pin of first one then we can shift the value bytes
Examples:
for display 5 on third LED we have shift the byte
00000100 then 0100100
Next :arduino Coding
Step 4: Arduino Coding
Picture of Arduino Coding
Connect the Latch , Clock ,Data pins to 8,10,9 pins of arduino (or any other one your wish )
I was written a code , that was take the 4 digit number from serial input and display onto the 4 LED
See the files for the Code
Note: I just designed it not tested , because presently i don't have arduino and LED
code written based on Imagination
martinhui (author)2017-03-04
may I check with you that your code is written for common anode display? how to change to common cathode display, I have done a similar code but only work for common anode, now I brought common cathode cannot work
v-nath (author)martinhui2017-03-05
invert the bits , then connect the common cathodes pins to ground ,
the shift registers can't deliver that power for 7 SEGMENTS use 7 transistor in between the data pins of leds (a,b,c,d,e,f,g,dot) and shift registers better to use ULN2803 , and invert the 4 controlled transistor (base pins as it is, connect the emmiter pins to ground and collector pins to common cathode )
madhavdivya (author)v-nath2017-03-12
Hi V-nath: HI, I got just ONE questions for you ?
What if the voltage is 24 v DC to drive the LED's?
Mine is a jumbo sized display of 3 digits in Common Anode Configuration.
I have put seven transistors (2N2222's), between the cathodes (seg. A to G) and GND. Every base of these transistors go to Q0 to Q7 of the first 74H595 through a 1k resistor.
Another set of 2 transistors is arranged between the +24v dc and Common Anode of each digit. The first transistor is NPN and the second is PNP, so that when the Q0 of the second 74H595 goes high, the anode of that particular segment goes high.
Is my understanding correct and technically feasible for my jumbo display ?
I appreciate your inputs.............madhavdivya@gmail.com
KiranM38 (author)2016-06-15
Thanks for this !
About This Instructable
1,859views
26favorites
More by v-nath:Multiplexing four 7-segment displays using Shift Registers Arduino Weather Display Using Arduino and Raspberry PiUsing Google Spread Sheets in IoT Projects
Add instructable to:
