loading
Step 9: 74HC595 Socket
Solder an 8-pin socket to the protoboard as shown in the images above.  It's always a good idea to use a socket for ICs; it prevents damaging the IC from the heat of the soldering iron and the IC can easily be removed and replaced if needed.
<p>So Q0-Q7 can be either 5v or GND? Should I then use N-channel or P-channel mosfet better?</p>
<p>Could this hold enough current to run no more than four 10mm brushless vibration motors at once? They are model: 910-101</p>
<p>If I were you, I'd attach the outputs of this IC to the base pins of transistors, not driving the motors directly. That's because motors often require more amps. The transistors could handle that across their collector-emitter pins, the IC itself could not.</p>
<p>Beautifully commented code dude.</p>
<p>Dudette even!</p>
<p>Seriously it warms the cockles of my heart to see someone take as much time with their comments as they do with their code, more even. The comments are more important and are completely ignored by the compiler, it's good manners and appreciated.</p>
<p>Hi there, <br>The codes aren't available any more. Any chance for an update or source?<br>Thx! </p>
<p>Hi, thanks for posting.</p><p>I used the code to drive 4 rows and 4 columns on my 8*8 matrix, as i could not find a good 8*8 based 74HC595 solution. Then I took it from there to implement a serialized implementation (2x 74HC595) to get all the 8 rows and columns going. </p><p>Took a while but i got it to work :-) I will try to post my solution later.</p><p>Thanks again!</p><p>I then adjusted it to drive the whole 8*8 matrix.</p>
<p>Hey MarkKI,</p><p>could you please send me the code you used.</p>
<p>Ugh...this IC has caused far more Headache then any other T_T</p><p>The thing is that the Chip itself is rated to a maximum current of 70ma in total, meaning that to drive more then a few Leds or such at a time is suicidal...And yet in Practice the chip seems to hardly break a sweat. this has resulted in a fissure between people saying it CAN and others that keep yelling it will Burn.</p><p>Personally Ive come up with the theory that people should take the datasheet with a grain of salt. It says 70ma in current perhaps, but it never specified if its the actual same voltage which in the end together with the current defines the actual Power in Watt being drained/sourced. Heck i have one right besides me that seems able to Drive a Numitron tube that draws 20ma at 3.3v with ease!</p><p>Great IC...although better clarity at its maximum should be looked into by the manufacturers...or whoever designed the first one of which all manufacturers have copied the design off.</p>
<p>If you want more current coming out of the 595, hook them up to transistors for lower current, or for higher current, you could use a relay.</p>
<p>If you want to supply more current then hook the 74HC595 up to an IRF1405 N-Channel Power Mosfet which will supply ~100Amps if you use a good heatsink. Or use an IRF4905 P-Channel Power Mosfet which will handle ~50Amps if you use a heat sink. Mosfets are good because they are high impedance devices and don't require much power to switch them on. *Latching* relays are very good too if you know how to configure them properly because when they are switched on they don't use any power at all to keep them switched on. They are just like an SCR [thyristor], because once they are switched on, SCRs stay switched on too until disconnected from the power supplying them.</p>
We don't perceive all of the LEDs to be on at once because of persistence of vision, we do because of flicker fusion.<br><br>You linked to the persistence of vision wiki article and in the first paragraph it clearly states that the perception of continuous light is due to flicker fusion...<br>The same reason why we don't see a common light bulb flicker on ac electricity<br>
<p>If you want to see the effect of persistence of vision with multiplexed LEDs then just blow air through your closed lips [whilst looking at a multiplexed 7 segment LED digital display] so that your lips vibrate strongly [making a sound like noisy sewing machine etc.]. Doing this makes your eyeballs dance about and you'll see each LED segment dance up and down too. Try to vary the frequency that your lips vibrate for best effect.</p>
<p>i have aded another 74HC595 so i have 8x8 matrix. I managed to make each led light up on it's own like in the first video but i am having trouble to modify the last code. Can anyone help ?</p>
<p>Just a POC but I did it :]</p><p>very good instructable thank you!</p><p>Am I wrong or with the 10x10 matrix setup and using BCM it's not possible to create change each LED brightness independently?</p><p>It looks like there might be too many operations to be executed within too short time frame :/ </p><p>or...?</p>
<p>Great project! I've been messing with this myself. Were you able to get a RGB led working with this board?</p>
<p>haven't tried yet, should be no problem if you copy this circuit 3x</p>
The issue I have had is with the matrix being based on ground. When I tried this X3 it caused all sorts of weirdness since the ground connection (I think) created a lot of closed circuits that shouldn't be closed. Basically lots of extra lights and colors. I couldn't get any isolation like X1 worked. <br><br>It's also quite possible I just did something stupid. Possibly I need some more diodes in the design to prevent some crossflow. <br><br>
<p>I just managed to get this working with common-cathode RGB LED matrix, with the help of a friend, and based on this: <a href="http://alvarorevuelta.net/the-core-of-midispositivomidi/" rel="nofollow"> http://alvarorevuelta.net/the-core-of-midispositi...</a> .</p><p>Basically, you need to connect all of the power and clock lines up in parallel, and connect the serial out (Q7') from the first chip to the serial in (DS) on the second chip (so you don't need to use any more pins on the arduino). Then you hook up sets of 4 parallel outs to the matrix. Now you need to send two separate bytes. The first byte will be send to the *second* chip, and the second byte to the one connected directly to the arduino. </p><p>I had troubles with interference - use filter caps between the VCC and GND pins of each chip. </p>
<p>If someone is interested, you can check out the whole project here (using the sparkfun pcb): http://alvarorevuelta.net/midispositivomidi/</p>
<p>Alternatively you may consider using a dual 2-to-4 line decoder (I just recently discovered these things existed):</p><p><a href="http://www.nxp.com/documents/data_sheet/74HC_HCT139_CNV.pdf" rel="nofollow">http://www.nxp.com/documents/data_sheet/74HC_HCT13...</a></p><p>use two lines to specify the row, and two lines to specify the column. This skips the serial-to-parallel translation stage with the shift register, at the cost of one extra line.</p>
<p>I would like to point out to the entire universe that what everyone is calling multiplexing is in reality DE-Multiplexing.</p><p>I don't know how or when it all got confused, but everyone is doing it now, and it kinds bugs me!</p><p>Multiplexing is when you take a large number if signals, and combine them into a few lines. A good example of this is when 500 apartments in an apartment building all have their telephone lines connected by one fibre optic line to the phone company. De-multiplexing happens when the fibre optic line comes back to the apartment and then becomes 500 individual phone lines. So what we are really doing with our microcontrollers sending out data that gets spread across a much larger number of devices or wires (LEDs usually) is de-multiplexing. If we were to take 250 push-buttons and connect them all to the Arduino with 2 wires so that it could tell which button was pressed, that would be multiplexing.</p><p>That said - Nice project!</p>
<p>I too, like to use the correct terms when explaining, and I understand your frustration, but this instructable is geared more for beginners, so &quot;multiplexing&quot; makes it easier to understand.</p><p>Actually it is neither multiplexing or demultiplexing. You could consider it a DEMUX because it is a serial to parallel conversion, but each output is staggered based on the clock (so it is 8 in 8 out --kinda/sorta), which doesn't occur using MUX or DEMUX. The best term I can come up with is &quot;Serial In to Parallel Out Shifted&quot;, which is awkward and wordy. Because it <strong>appears </strong>to multiply the output (persistence of vision), multiplexing is a (wrong) but better explanation.</p>
<p>Serial to parallel conversion is the most common form of demultiplexing.</p><p>The outputs do not have to be simultaneously active and actually rarely are.</p><p>Take the 74HC138 or 74HC238 which based on a binary number, demultiplex the single bit input to one of it's 8 outputs. Only one of the 8 outputs is ever active at once by design, and it is a demultiplexer. You can send 10,000 bits to output 1, and then send 10 bits to output 5 and then send 2 bits to output 6 - but it's still demultiplexing by definition.</p>
<p>Since I no longer am employed in electronics, I don't know enough to give you a good argument. My last formal schooling was building 555 timer circuits using transistors, caps, etc.; logic gates from diodes. :) Troubleshooting tube based radios. (Anybody know about the ARC51 and tuning using sharpened wooden rods?) Fun Fun. (Navy Schools). Now it just a hobby, after leaving the Corps in '97.</p><p>Now I am on the software side of IT. (DOTNET rules!) Not to impose on Linux followers, I have a UBUNTU stick whenever I want to experiment, and I first started programming using LAMP.</p><p>Those two chips you referenced look to me that they are all composed of logic gates. Some outputs look staggered, but I don't see a clock signal. Is this delay intentional, or just a side affect?</p>
<p>I don't know what you mean by delay - the only delay these chips might have is the tiny insignificant amount of propagation delay between input and output - otherwise it's pretty much instantaneous. The chips I mentioned have no clock. There are 2 inverted enable lines, 1 non-inverted enable line, any of which could be considered the &quot;data&quot; being presented at the output. If the inverted enables are grounded, and the other enable is at +v, then a &quot;1&quot; will be at whatever address is presented to the 3 address bits.</p><p>Yes, if you wanted to, you can break just about anything down into discrete gates, and if you did that with this chip, it would look like this for the 74HC238 (invert the outputs for the 138). </p>
<p>If you wanted this chip to distribute data evenly across the 8 outputs with respect to a clock, then all you'd have to do is connect the non inverted enable to your &quot;data&quot; bit, and put the clock into a counter like a 74HC393 and use 3 bits of the counter's output as the address bits going into the 238's address lines. Since the 2 counters in the 393 are 4 bits, we would simply tie the 4th bit of the counter we are using to the reset line so that it becomes a 3 bit counter. VOILA, multiplexed serial in to 8 demultiplexed serial out. </p>
<p>Thanks for the clarification, but if I had to explain the difference to my wife, it would go right over her head and simplify via this Instructable.. :) </p><p>As far as the ARC-51 goes, I never thought about Googling it, as all of our pubs (at the time) were classified material. Maybe since they have been phased out you can now download the schematics. </p><p><a href="http://members.home.nl/a.k.bouwknegt/index_bestanden/ARC51_UHF_Transceiver.htm" rel="nofollow">http://members.home.nl/a.k.bouwknegt/index_bestand</a> I wish I had that resource back in the 80's instead of digging through 5 inch binders. :) Kinda cool. Now if I can find that power supply schematic for an APX100 (IFF) that supplied 2000VDC (my guess but I know it was over a thousand volts) from aircraft power. I still have a scar from that little bugger, it was smaller than an ATX PS. Burned a hole right through my palm. If you can find it, it had one card that was composed entirely of diode gates.</p><p>Again, thanks for taking the time to reply and clarify!</p>
<p>It would have been diodes and capacitors, because what you are describing is a simple voltage multiplier. A scaled down schematic is here...</p>
<p>Finally found the original manual that I used daily. I can't upload it because it is over 800 pages. I downloaded it, closed my browser, but now I can't get back in. But if you go to http://www.liberatedmanuals.com and do a search for NAVAIR 16-30APX72-2 it should let you view it. That site limits the amounts of downloads/day. Here is a functional diagram and a schematic (sorry a bit fuzzy).</p>
<p>Well, I think we have strayed far enough off topic on this poor man's thread.</p><p>This started out as multiplexing VS demultiplexing, so I think I am just going to terminate our personal sideline here. If you wish to keep discussing things like this, then you can inbox me or post on my orangeboard.</p>
<p>I need to get back to work on my RGB LED cube PC boards anyways.</p>
<p>As an aside, I don't think many here have ever seen an ARC51 tranceiver.</p>
<p>And how does that work with PWM &quot;data&quot;? Can registers &quot;remember&quot; the pulse width?</p>
<p>you can't do pwn output with a 74HC595, check out the <a target="_blank" href="http://playground.arduino.cc/learning/TLC5940#.Uy4ORF6SIpM">tlc5940</a> instead</p>
Awesome! Any idea how I can do this with 100 RGB LEDs? :)
//LED TEST 2 w/ 74HC595 <br>//by Amanda Ghassaei 2012 <br>//https://www.instructables.com/id/Multiplexing-with-Arduino-and-the-74HC595/ <br> <br>/* <br> * This program is free software; you can redistribute it and/or modify <br> * it under the terms of the GNU General Public License as published by <br> * the Free Software Foundation; either version 2 of the License, or <br> * (at your option) any later version. <br> * <br> * This program is distributed in the hope that it will be useful, <br> * but WITHOUT ANY WARRANTY; without even the implied warranty of <br> * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the <br> * GNU General Public License for more details. <br>*/ <br> <br>//this code will display the values of ledData across a 4x4 led matrix <br> <br>//pin connections- the #define tag will replace all instances of &quot;latchPin&quot; in your code with A1 (and so on) <br>#define latchPin A1 <br>#define clockPin A0 <br>#define dataPin A2 <br> <br>//looping variables <br>byte i; <br>byte j; <br> <br>//storage variable <br>byte dataToSend; <br> <br>//storage for led states, 4 bytes <br>byte ledData[] = {1, 3, 7, 15}; <br> <br>void setup() { <br> //set pins as output <br> pinMode(latchPin, OUTPUT); <br> pinMode(clockPin, OUTPUT); <br> pinMode(dataPin, OUTPUT); <br>} <br> <br>void loop() { <br> <br> for (i=0;i&lt;4;i++){ <br> <br> //send data from ledData to each row, one at a time <br> byte dataToSend = (1 &lt;&lt; (i+4)) | (15 &amp; ~ledData[i]); <br> <br> // setlatch pin low so the LEDs don't change while sending in bits <br> digitalWrite(latchPin, LOW); <br> // shift out the bits of dataToSend to the 74HC595 <br> shiftOut(dataPin, clockPin, LSBFIRST, dataToSend); <br> //set latch pin high- this sends data to outputs so the LEDs will light up <br> digitalWrite(latchPin, HIGH); <br> <br> } <br>} <br> <br>
//LED TEST 2 w/ 74HC595 <br>//by Amanda Ghassaei 2012 <br>//https://www.instructables.com/id/Multiplexing-with-Arduino-and-the-74HC595/ <br> <br>/* <br> * This program is free software; you can redistribute it and/or modify <br> * it under the terms of the GNU General Public License as published by <br> * the Free Software Foundation; either version 2 of the License, or <br> * (at your option) any later version. <br> * <br> * This program is distributed in the hope that it will be useful, <br> * but WITHOUT ANY WARRANTY; without even the implied warranty of <br> * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the <br> * GNU General Public License for more details. <br>*/ <br> <br>//this code sends data to the 74HC595 without &quot;shiftOut&quot; <br> <br>//pin connections- the #define tag will replace all instances of &quot;latchPin&quot; in your code with A1 (and so on) <br>#define latchPin A1 <br>#define clockPin A0 <br>#define dataPin A2 <br> <br>//looping variables <br>byte i; <br>byte j; <br> <br>//storage variable <br>byte dataToSend; <br> <br>//storage for led states, 4 bytes <br>byte ledData[] = {1, 3, 7, 15}; <br> <br>void setup() { <br> //set pins as output <br> pinMode(latchPin, OUTPUT); <br> pinMode(clockPin, OUTPUT); <br> pinMode(dataPin, OUTPUT); <br>} <br> <br>void loop() { <br> <br> for (i=0;i&lt;4;i++){ <br> <br> //send data from ledData to each row, one at a time <br> byte dataToSend = (1 &lt;&lt; (i+4)) | (15 &amp; ~ledData[i]); <br> <br> // setlatch pin low so the LEDs don't change while sending in bits <br> digitalWrite(latchPin, LOW); <br> <br>// // shift out the bits of dataToSend to the 74HC595 <br>// shiftOut(dataPin, clockPin, LSBFIRST, dataToSend); <br>// the code below is the equivalent of the two lines above <br> for (j=0;j&lt;8;j++){ <br> digitalWrite(clockPin,LOW); <br> digitalWrite(dataPin,((dataToSend&gt;&gt;j)&amp;1)); <br> digitalWrite(clockPin,HIGH); <br> } <br> <br> <br> //set latch pin high- this sends data to outputs so the LEDs will light up <br> digitalWrite(latchPin, HIGH); <br> <br> } <br>} <br>
arabic letters!!! do u have any idea if is there any software used with arduino to blink led screen????
thanx dear for answer... <br>because i am new to work with arduino... <br>i have some problems about alphabet [][] function cuase i dont know how does work and how it generate litters and how can i generate latin words by using ascii??? <br>best regards....
what letters do you want to make?
I'm guessing we could use 3 74HC595 circuits with an arduino to control RGB LED's that this board was intended for use with? If we had 9 analog pins on an standard arduino that is. If we could use the same clock pin for all 3, that would cut down the pins to 7. It looks like a Mega would be the only way to make this happen.
dear sir... <br>u have explained 4*4 led matrix connected to arduino.. <br>but i dont have any idea how to connect 8*8 leds using 74hc595 to arduino???any help plz
same idea, but you need two 74hc595 - one connects to the 8 rows and the other to the eight columns.
Hi, I've been reading about muxing and things, and the title of this instructable is kind of confusing to me because if I'm not mistaken you're using a shift register, not a multiplexer. Is there not a significant difference?
the terminology is kind of ambiguous, a shift register implies something digital, like the chip I'm using. Multiplexing in general is this technique of controlling an array, a multiplexor is something that does the multiplexing. often people refer to analog chips as mux/demux and digital as shift registers, but they both do multiplexing.
Hi It's really Nice Instructables, but can this method to light up up to 120 button simultaneously , thank you very much
yes, definitely.
Great Instructable! <br>One this I am a bit confused about. What is you want to light more than one LED at once. <br>Wouldn't this cause some other lights to illuminate unexpectedly using this method?
About This Instructable
476,080views
577favorites
License:
Bio: I'm a grad student at the Center for Bits and Atoms at MIT Media Lab. Before that I worked at Instructables, writing code for ... More »
More by amandaghassaei:OTCA Metapixel - Conway's Game of Life "9 Degrees of Freedom" IMU Twitter Controlled Pet Feeder
Add instructable to:
