3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Multitouch Display (FTIR)
This Instructable will show you how to turn your lcd projector into an interactive multitouch device.
I spend ~185 euro
may you can excuse my bad englisch ;D
Things you will need:
1 beamer
1 webcam - modified this way
1 mirror
~50 IR-LED's I used these ones
stuff to make the LED's work
for example wires,10 resistors and a power supply unit
1 acrylic glass
1 transparency paper
Things you will need to setup the wooden box ,... for example wood ;D
Power glue ;D I used Patex extreme repair
silicon rubber
other great intructions :
by turkey tek
and Christopher Jette
Step 1How does it work ?
How does it work ?
Basically I'm working with infrared light.
LED's placed all around the acrylic glass 'fill' this acrylic glass with infrared light due to the total internal reflection. If you now touch the acrylic glass your finger reflects infrared light and the infrared webcam will see it. you may take a look at the image below to understand.
picture was taken from here
the picture coming from the webcam can now be read by tbeta or your self-made software ;D
this technique makes it possible to read many user interactions at the same time.
for further information on my setup please see the second image below
1) acrylic glass
2) infrared LED.
3) diffuser
4) mirror
5) Webcam
6) Beamer
22 comments
Mar 15, 2011. 9:22 AMf8ie says:
hi! probably a stupid question...
but does it matter how thick the acrylic glass is?
Jun 8, 2010. 7:13 PMmesatactil says:
Hi, I've Made the multitouch display last year and I didn't use the transparency paper, all worked fine, but the light its very strong, now I'm Trying to make a new one but the problem is that I don't know what paper is it, and it's more difficult because I'm from chile and I dont Know the name in spanish (lol). I don't know if you can take some photos to the paper or a specific description :D, I have seen somewhere else that some people use a paper called greaseproof paper (in spanish is "papel vegetal"), do you know if I can use that paper. Thanks! And in my opinion this is one of the best instructable ;)
Jun 10, 2010. 5:19 PMmesatactil says:
Nice man! thanks, now I understand what paper is it :D yeah, it is very similar to "papel vegetal". Thanks again and I will ask you again if needed :D Bye!
Sep 9, 2009. 8:42 AMjudecru says:
sir.. how about the term you used , "BEAMER" , what exactly is that..does beamer is same as the projector...if so..sir can you give me some specification regarding it...anyway sir thank you for answering my question....
Mar 9, 2010. 12:24 PMm2father says:
I bought a USB picoprojector  that is much cheaper than traditional projector but with less resolution as 640x480.
Do you think it is workable with your design ? Please advice.
Sep 11, 2009. 12:23 AMjudecru says:
thanks again..it helps me alot in this project..by the way, hope you don't mind, i still have some questions regarding the angle between the beamer and the mirror, and the value of the resistor should it be exaclty 37.5 ohm or can i use 38 or 39 ohm..and how about the glass can i use ordinary glass for this project..right now i plan to work using 2ft. x 1.5ft glass..is ordinary glass sheet possible for this project? sir..again thank you so much for your patience in answering all my questions
Aug 10, 2009. 9:52 PMhoratio cheng says:
the main idea of this project is to allow the camera to see the ir light spot, so could i just make a stick that emit ir light so i can directly point at the whiteboard rather than making the screen
Sep 1, 2009. 12:37 AMjudecru says:
sir...i found your project is interesting that's why i plan to make one...but i have a little confusion regarding the way you assemble the leds in connection to the glass...sir can you give some advice or points in assembling this project..thank you
Mar 25, 2009. 7:08 AMmasterpj says:
How did the webcam view trough the mirror?? In that example a big part of the view is blocked by the mirror above it???
Sep 1, 2009. 12:38 AMjudecru says:
sir...i found your project is interesting that's why i plan to make one...but i have a little confusion regarding the way you assemble the leds in connection to the glass...sir can you give me some advices or points in assembling this project..thank you
Aug 24, 2009. 10:46 PMhoratio cheng says:
thank for the answer.....
Aug 5, 2009. 6:19 AMmesatactil says:
hello, with a group of friends, we are buying the things and we have a question... what color have to be the LEDs??. bye
Aug 10, 2009. 2:08 PMmesatactil says:
ok, thanks!
Feb 15, 2009. 12:22 PMJakeTobak says:
Very kewl, I've always wanted to make on of those myself. I like your design, makes me want to build a desk with a screen on the side of the table top. I'll be moving soon and I only plan to stay at this next place for a couple months, so maybe when I get settled down I can give it a shot.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:rahi
