3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Munny Speakers
Step 3Heat 'im up!
Heat \
The vinyl that the Munny is made of is pretty firm when it's at room temperature, but heat it up with a hair dryer or a heat gun and it softens up oh so nicely. After that the Xacto cuts through it like butter.
Cutting is all about careful subtraction. I cut within my safe area quickly, but when I was getting close to my line I started whittling down the space with constant checks with the drivers and eyeballing it from the side to see where I needed to remove more vinyl next.
4 comments
Sep 19, 2010. 9:47 AMbig_F says:
You can also heat it up in hot water, if you don't have access to a heat gun or hairdryer. I've used water for reshaping miss-formed Vinyl parts many times.
Jan 5, 2012. 10:47 AMredfoday says:
could you do it in the oven? if not do you boil water or just sit it in hot water?
Apr 6, 2012. 6:02 PMbioboy725 says:
could you use a hot knife or soldering iron to start a hole and use a dremel to finish it off?
Nov 26, 2008. 7:19 PMdecatur says:
I have to admit it didn't occur to me to heat up the vinyl before hand, well atleast it will be easier next time
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1414
Author:fungus amungus(my site)
I like to make things both useful and odd. The odd projects are usually more fun. I'm also the Content Manager here at Instructables. Follow @edabot for more
