Remove these ads by
Signing UpStep 1Gather Materials
Materials and Tools Needed:
*An old (preferrably non-working) PC or PC case with an interior width of around 17.5" on one side, as this is about how wide a rack-mount device is. You should definitely measure whatever rack gear you will be using to get a good fit.
*Metal cutting tool (Dremel with a metal cutting wheel, Sawzall, grinder with a cutting disc, plasma cutter, etc.)
*Machine bolts, nuts, and washers OR rack mounting screws and hardware
*Screwdriver
*Drill with bit OR screw bit for Dremel tool
*Permanent marker
*Tape measure
*Gloves (metal is sharp!)
*Saftey glasses (Please!)
Optional
*Hammer
*Center Punch
*Hot glue gun or tape
Alternatively, hitting the top of the rivet with a bit that's larger than the outside diameter for just a second will also break it off, but you want to stop drilling before you hit the panel/sheet that the rivet previously held to prevent any unsightly differently-sized additional holes.
A Dremel with around a 3mm bit and set to full speed will make light work of any rivet sizes used in the above project or anything similar
