Music Festival Group / Sign Pole
 by silence04
Featured
Step 3: APPLYING PAINTERS TAPE
On both Cor-Plast Ovals, apply blue painters tape all over one side.
Temporary tape the stencil to one of the Cor-Plast Ovals.
With the Xacto Knife, cut the the blue tape in the areas that are stenciled. (be careful not to cut through the Cor-Plast)
Remove stencil, then remove the blue tape from the areas that will be painted black.
Repeat with other Cor-Plast Oval.
NOTE: If you feel uncomfortable cutting the tape directly from the stencil, trace the blue tape with a marker. Then remove the stencil and cut.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
