3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Music Flashing LED Lights how-to
video Music Flashing LED Lights how-to
23 comments
Apr 11, 2011. 12:42 AMrandyrogers04 says:
if i was going to do something like this in my car, using 8-10 leds per color, what size resistors would i need? I would use Red for my lows, Blue for mid, and white for highs. would i need anything else in order to do all of this?
Jul 20, 2011. 12:00 PMsharksplayer33 says:
hey i am trying to do the same thing, have you found a way to do it yet?
Dec 14, 2010. 12:39 PMtrev2395 says:
Can you guys do a IN DEPTH tutorial because im a noob at this stuff and its freaking sick and I want to do it really bad but its too confusing.
Nov 29, 2010. 9:44 AMcreator22 says:
thats so tight!!!......only thats total poo! i hooked mine up just like yours but nothing happens???? then i took a volt reader an im only getting 0.1volts out of the speeker :/ why is this( speeker works 100% well) you must be using an IC or something that you not telling us...right??????? PLEZ HELP i think thats so cool if i could get it working!!!
Nov 30, 2010. 7:29 AMcreator22 says:
thanks! but i only used one led befor doing a bunch so i dont wast my money... i tryed turning up the volume but am still not getting more than 0.5 volts and i think they need about 1.5-2.0 volts? oh man this vid is so tight!
Dec 1, 2010. 11:22 AMcreator22 says:
well the speaker is about the size of the one in your vid maybe a tad bit smaller. yes i tried both ways on the led. do realy good speakers use less power than a junky one cause i have a pretty gooood one. i spend a lot of time building things so i have a verygood understanding on electronics and how they work.... i just can't fig this one out>>>would the woofer hav more power???
Dec 3, 2010. 5:42 PMcreator22 says:
also where can i get led's for chep
Dec 3, 2010. 1:02 PMcreator22 says:
IT WORKS!!! what led's should i hook up to which speaker ??? as in what did you do. How many of each color did you use? oh i got it working on the other speaker to
Dec 4, 2010. 2:44 PMcreator22 says:
haha true!:) ok your probly tired of me so last one...i think.
ok so if i hook up say 6 led's, would the volume have to be higher then if it were hooked up to only one led...is it possible to make a power amp :/ ???
Nov 9, 2010. 6:06 AMfidgety2 says:
i feel as though i have been living under a rock my whole making life oooohhhhh the shame the terrible horrible shame i just found this and it looks amazing beyond words. i will make this it is my destiny
Oct 13, 2010. 9:34 PMthe_burrito_master says:
I'd suggest using some transistors you wouldn't need to blare the audio in order to get light with low power systems. tip31 are great for audio bake sure to put a 22k ohm or more resistor on the collector tho, then just wire it up quite similar to this but add a 9 volt battery into the makeup.
Sep 16, 2010. 9:42 AMtrishya says:
hi, is there a way to simplify the wiring to speakers and solder to a mini stereo jack (which would limit to 2 channels instead of 3) and thus plug into a basic hedphone to mp3 player? maybe not enough power/ signal. but not opening speakers either. im going to look into controllers. very nice instuctable, Thanks!
Aug 29, 2010. 12:31 PMMavamaarten says:
Sweet :)
Jun 14, 2010. 9:31 AMungipungi says:
hey you guys. i have a car system witch is very powerful and do you think i can make lightshow like this in my car
Jul 27, 2010. 1:18 AMblindrulz says:
hey i have an idea n it work to a limit just buy neon light (12v) for car and connect it to your one of the speaker line u will see the effect ,it will glow according to the bass(if u connect to amp but dont increase the volume to very high........) check it out it realy workz...........
Jun 7, 2010. 1:21 PMSoksume says:
this is a very well directed Instructable great work the only question i have is how quiet can you have the speakers while the leds are still flashing ?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
145
Author:HM-Innovations(HM-Innovations.com)
We are a group of Engineers, Tinkerers, Designers, Programers, and Nerds ! ---- and Since April 2011 We also have a Cupcake Maker
