Step 5Preparing the circuit
Other instructables had no good explaining on this subject.
So for everyone who's new to this electronics stuff and have no idea what they're doing, here is some explaining for the circuit.
1. How many LED's to use?
The average LED needs 3v to work. If you are going to put the LED's in series (like I did) you need to calculate how many LED's you can use with your adapter. The formula you can use is adapter output voltage / LED voltage = Total LED's
So if you use a 12v adapter with the 3v LED's its: 12 / 3 = 4 LED's
You can also put LED's parallel in the circuit. But I'm not getting into this, just so that this instructable stays simple and easy to understand for everyone. Let's just focus now on the LED's in series.
If you want to experience with more LED's, you can always calculate your LED's and resistors here.
2. The real voltage on a adapter.
Before I went building this circuit, I thought it would be useful to measure the real voltage on the adapter. The sticker on the adapter (photo 1) says the output 12v. But once I hooked it up on my multimeter, it shows that the actual output is around the 18v (photo 2).
So that means I can calculate the LED's again: 18 / 3 = 6 LED's.
Since I'm going to make the LED's in series I can use 6 LED's in my circuit.
3. The 3.5 audio jack plug
Which wire is what? That's what I was asking and trying to find out.
As you can see on photo 3, the plug itself has 3 metal parts, and 3 wires in the black protective layer.
On the photo I explained which wire is what.
Now with this information you can go to the next step, building the circuit.
I think it is right can anyone correct me if I'm wrong.
Short answer: Yes.
Thank You
By using 6 LEDs in series though, you kinda over corrected yourself so the circuit isn't dangerous, per se, but it isn't exactly something that would please the electrical gurus out there, if you know what I mean.
w 3.4v leds- 3 in series and 180 ohms across 12vdc works well.
for 2.1v LEDs use 5 in series and 180 ohms across 12vdc.
for mix and match use ohms law. 13.8 (supply) or 12.7 battery minus drop of the led string divided by .02(ma)= value in ohms. r,g,b,= 2.1+3.4+3.4=8.9.
12.7v -8.9v= 3.8v divided by .02 =190 ohms. 200 or 220 is next highest fixed resistor. good luck with your projects.
First step, find out the stats on ur LED. That should be available from the supplier. You're looking for the current capacity, specifically. Or, if you're feeling lazy, just assume it's 20mA, which is pretty standard for a LED. Then, figure out your voltage supply. In this particular instructable (and 99% of cars), your supply is 12V. So, plug in your knowns into oh-me-oh-my's-law so you get
(0.020A)*(?R?)=(12V), use some complicated differential equations or calculus algorithms to solve (no, really just divide 12 by .02) to get R=600ohm.
What you just solved is that if you are going to put a single LED rated at 20mA in a circuit with a 12V supply, you must put a 600ohm resistor in series in order to prevent blowing out the LED. You have a bit of a fudgefactor here, so dont' worry if you only have a 500-700ohm resistor handy. Just be aware that if you go too low on resistance (or if you supply voltage fluctuates considerably higher, although unlikely), that you run the possibility of blowing your LED. Generally, it's a better idea to just accept a *slightly* dimmer LED (with a larger resistor value) than risk it popping and then going through the hassle to replace it.
Your other option, if your feeling TOTALLY lazy, is google "LED resistance calculator" or something of that nature. There are a ton of sites out there with little website calculators for that purpose. But, IMHO, I think that takes the joy out of building things if you just cheat every step and don't understand the concepts behind why what you're building is working.
I'm actually planning a switch in mine so could I possibly run a resistor from the switch to the power supply?
I believe that the total amperage will be 180mA (6 red 20-30mA LEDs) since it is 20-30, should I assume it will draw the max while figuring resistance? If I use 180mA this will need 66Ω of resistance in this case, will a 100Ω resistor work, or would I be better buying some new 75Ω resistors?
And actually, for 6 LEDs I would be drawing 13.2V from a 12V supply at the max for the LEDs. Will this be a problem if both banks max out at once?
Thanks
100ohm vs 75ohm?? Consider it like this....
live 100 boring years
or
live 75 happy lightened up years ??
And I understood your 4th question, I have to add that it´s always a problem messing with electronics when we´ve got little experience, but making a few Ohm´s excercises will get you on shape.
a. If both banks(you mean branch?) max out at once??
Thanks for the info about the resistors. I understand Ohm's Law equations.I'm just wondering, do you still use 12V when you have 2 branches from the power supply or would it be split through the branches, and do you just figure the amperage draw for that specific branch or the total draw?
If it's total draw at 12V, I need about 75Ω, if it's branch draw at 12V, I need 130Ω I have some 100Ω (They're cheap so I don't care if I need new ones, just need to know what's needed)
cliff notes:
a current limiting resistor should always be used to dissapate heat and stop the circuit from shorting out.
1/8 watt resistors will be fine for most string of leds 3-4 long
the power supply in this case is cheap so there will be voltage drift. that is to say that as you add a load to this power supply it will become more efficient and the V will drop. if you put your multimeter leads across it it may read higher than when you attach a circuit to it and measure the V again
