Music Flashing LED Bar
 by HM-Innovations
Ever seen the LED bars found at clubs or raves etc. ?
well we'll show you how to make a bar similar to those in an easy step by step instructable. All you need is a little bit of thinking and you can make this in any way you want. Ultimately this light bar is only a model and you can modify it in several different ways and even make it extremely extravagant. Like all of our instructables and videos, have fun and make it even better than us. We'll give you the ideas, ya'll make them better!
Good Luck, With that said, lets begin this awesome project! if you want a step by step instructional video watch the video bellow, if not, go on to the first step.
Enjoy
Step 1: Getting the Supplies
You will need a couple of supplies for this project, most of which you can find on E-bay (if you need a cheap price) or your local hardware store or even laying around your house.
You will need a number of LED"s depending on how big, or how extravagant you want your light to be you will need more LED's you will use etc.
For our light we used,
28 -LED's with 4 different colors.
    - White =10
    - Blue = 3
    - Green = 3
    - Red = 4
28 -120 Ohm Resistors
54 - 1" x 1" square pieces of glass
   - we found these in a pack of 24 at Hobby Lobby for $3.99
You also need several pieces of speaker wire and jumper cables.
A 48" piece of wood, if you want the bar to be larger you would go out and buy a larger piece of wood.
For your tools you will need:
Dremmel Drill
1/16" Drill Bit
Soldering Gun
Metallic Paint
Surround Sound or speaker System :)
jleonard9 says: Jan 26, 2013. 1:13 PM
Wow, this seems like the perfect project for me, but looking over it, I thought up some questions. If I hook these directly up to the speaker, It has to be getting it's power from it then. So I was just curious if the amount of power to flash say... 10 LED's from one speaker would be noticeable, especially if I have matching left and right speakers, and I only hooked up the LED's to the right one, would the sound be noticeably dimmer? Also, you hooked it directly up to the speaker, I imagine that is what allows you to get distinguished flashes, but if I hooked it up to my receiver directly, would I still get flashing LED's, or would that burn them out? Really interested in this, thanks for the tutorial!
snipesome says: Jan 25, 2013. 2:00 PM
Can you please link me two the mirrors I can't find them on hobby lobby
chetancc says: Nov 24, 2012. 7:15 AM
Where is the circuit diagram?
brobertsmhs2009 says: Aug 2, 2012. 1:15 PM
Hey, I have Klipsch Pro Media 2.1 Speakers I was wondering if you could recommend how to connect the led's to my speakers. They do have the left in right speaker inputs as the spring inputs, but I am unsure as to how to connect the "white leds" to the subwoofer.
Thanks,
Bryan
gm93d says: Jun 20, 2012. 8:54 AM
This is great but can you give me the circuit.
gm93d says: Jun 20, 2012. 8:52 AM
yissa says: Apr 26, 2012. 6:14 AM
Hi, great video =) could you please explain how you connected the resistors and LEDs with the speaker!!! And if I could use instead of a sound system, for seperate speakers connected to an amplifier? Looking forward to a response =)
tviskovic says: Apr 14, 2012. 2:25 PM
Do you have any sheme, if you have please post to comment.
Thanks!
onlystatic says: Nov 27, 2011. 2:05 AM
thank you. i think this is project is a great way to start out learning of L.E.D.S. i honestly think alot of people are missing the point of its simplicity. its a great learning tool and i appreciate you guys at HM-Innovations taking the time and effort to post it. thanks guys, keep up the good work and keep projects like these coming.
King Julien says: Oct 22, 2011. 12:32 AM
Is it really that easy? You just connect the led wires to the speaker wires?
nodoubtman says: Aug 28, 2011. 6:45 AM
LED color's have a different intensity, you cannot put a same value of the resistor for each led?
THank YOu!
CYa!
HM-Innovations (author) in reply to nodoubtmanAug 29, 2011. 11:20 AM
You can use a resistor for the weakest LED and then the otherones shouldn't have a problem
saif.mac says: Aug 5, 2011. 6:51 AM
in 1:30 minute in this video who is the name song ?
HM-Innovations (author) in reply to saif.macAug 7, 2011. 10:49 PM
I completely forgot the name of the song, it was so long ago.
saif.mac in reply to HM-InnovationsAug 9, 2011. 3:43 AM
ok thnx man ;) this is awsome instructable i made it but it dont work can u give me a simple circuit
gbmaster137 says: Jul 17, 2011. 8:11 PM
how many volts should the leds be?
hsarode1 in reply to gbmaster137Jul 25, 2011. 12:47 AM
Look wat u have to do is select the input u r goin to put n then divide the number of LEDs u use by it
Example
Input. 9 v
No. Of LEDs 3
Voltage of led. 9/3 = 3
So ur led should be 3 v.
I am not 100% sure that it is correct.
hsarode1 says: Jul 21, 2011. 1:48 AM
Should we connect 1 resistor to 1 short leg and the other end of resistor to the long am i correct.
dog digger in reply to hsarode1Jul 21, 2011. 2:08 AM
No. One resistor per LED. Connect it to the shorter lead or the longer lead. Your choice
ctheodorou says: Jul 14, 2011. 3:04 PM
that bar is only 48 in long? it looks way bigger
fastcar123 says: Jun 29, 2011. 12:36 PM
Could you connect one resistor from the speaker and then wire a parallel circuit of LEDs from that or will it not work that way?
MARSHALLLP says: Jun 1, 2011. 11:22 AM
where i can get that last song, sounds like an amazing remix! What is the title?
Also GREAT instructable, i really wanna try building this one
Steeps5 says: Apr 29, 2011. 4:50 PM
You did mean to say 1.5" squares of glass correct? I would say 0.5" squares of glass are awfully small.
HM-Innovations (author) in reply to Steeps5May 1, 2011. 11:15 AM
1" by 1" good catch!
bkeaton says: Apr 27, 2011. 12:27 PM
I don't think it is necessary to open up your speaker enclosures and solder anything to the speakers in order to connect this light bar to your sound system. Why not simply tap into your sound system right where the speakers themselves attach? The speakers attach either via a spring clip or screw terminals. The only way this would not work is on some of the less expensive systems where the speaker wiring runs directly into the receiver.
HM-Innovations (author) in reply to bkeatonApr 27, 2011. 5:17 PM
Yea this way is way better, it wasn't until after we made the video that we realized it was an easier and probably better to do it your way.
kctess5 says: Mar 15, 2011. 9:07 PM
Thats a somewhat inefficient way of doing this. I just use a tip31 transistor off my audio splitter. That way your not sucking power from your system. And you can more easily control max power to leds. And I don't usually set it up with one resistor per led. I just do like one for about 10-20 leds, though I know that a lot of people do it this way
wingchangwow says: Mar 5, 2011. 6:59 PM
that's only 26 led's
chaddu says: Feb 6, 2011. 8:27 PM
What voltage was the LED's that were used on this project.
dr.shah says: Jan 2, 2011. 9:14 PM
How much MCD the led need to be ???and also what about their voltage??
thnks
jeppers113d says: Jan 2, 2011. 5:43 AM
so what's correct 120 or 270? and has anyone been able to get this to work? i have 3 led's with 3 270's and they all just stay on and don't blink =\
jeppers113d in reply to jeppers113dJan 2, 2011. 1:09 PM
do you have a schematic? i still can't seem to get this to work blah. ok here's the hook up tested 3 LED's, i have a 12v power supply connected + to the side with the resistors, and the - to the other side with the longer anode i think its called? then from there the output of the resistor side i connected to my computer speaker + and the negative side of the device to the - .
with this hook up the LED's just turn on and stay on, if i switch it around the LED doesn't even turn on. thanks for your help
HM-Innovations (author) in reply to jeppers113dJan 2, 2011. 5:53 AM
120ohm sorry bout that.
jeppers113d in reply to HM-InnovationsJan 2, 2011. 7:35 AM
no problem thank you, does watts matter in this ?
HM-Innovations (author) in reply to jeppers113dJan 2, 2011. 3:36 PM
Yea your problem is with the power. All the power comes from the speaker, connect one LED to the possitive side of your speaker using the Resistor and the other end of the LED (anode) to the negative side of the speaker thats all you need. If you add power the LED will remain on throughout the whole thing.
MKJIPK says: Nov 17, 2010. 10:01 AM
I have 2 questions:
Where does the power come from?
Is it necessary to take the speaker apart or can the positive and neg wired going to the speakers just be spliced?
streetcurl says: Sep 21, 2010. 10:12 AM
Hi can go send me a graphic how you wired it because i can't see it well here ?
sasho_8 in reply to streetcurlOct 25, 2010. 1:24 PM
I also can't see it :S:S
sasho_8 in reply to sasho_8Oct 29, 2010. 1:38 PM
and I need these graphic ...:S:S:S
sasho_8 says: Oct 25, 2010. 1:28 PM
which are these songs??
xanxor says: Oct 17, 2010. 1:22 AM
what is the output of your speaker? I'm planing to do this but on my car. and I'm pretty sure my speaker needs more current than yours.
14karma says: Oct 5, 2010. 5:59 PM
in one of the pictures in this instructable, it has 270 ohm resistors listed. But in the text it says 120 ohm resistors. I ordered the 270 ohm resistors. i am planning on using the light bar with a PA amp. Will these larger resistors be better suited for my higher power application. Or do i need to order the 120 ohm resistors for this to work
dogs10109 says: Sep 21, 2010. 8:03 AM
It says:
"The short end of the LED will all be connected together with a 120 Ohm capacitor in between each of the LED's"
I was just wondering if you meant resistor when you said capacitor?
(I'm assuming you meant resistor)
HM-Innovations (author) in reply to dogs10109Sep 21, 2010. 11:05 AM
yes sorry i didnt even catch that
pink piggy says: Sep 8, 2010. 10:12 AM
hello..sorry for my english..nice work..
but i have an ask..
you have there any IO as for example A277D or so??you have only led and resistors and this you join only with speakers??
this is really simple and nice efekt..but i have concerns, how good it work.....
but..really nice..i want this same in my car but only with white LEDs..so i think, if i can make this same..
Eonir says: Sep 7, 2010. 12:26 PM
Schematics, please.
fardown says: Sep 6, 2010. 10:23 AM
any chance of "Clearer" pics? or a diagram or something? Really hard to see what connects to what..
tfultsucf says: Sep 2, 2010. 1:25 PM
Great instructable! I've been working on a project similar to this placing the LEDs directly inside of the speakers. Without resistors it was fine at lower volumes on my 200W home theater system but as the volume went up they became overloaded. How much power did your system put out? I've also been trying to find a circuit diagram or computer program to allow for more fluid and gradual light changes for different frequencies unfortunately I haven't come across anything promising yet. I may integrate different resistors to get a VU meter type of effect within each set of colors.
HM-Innovations (author) in reply to tfultsucfSep 2, 2010. 2:50 PM
I have no idea how much it really puts out. but when we placed them directly without the resistors they went out at about level 11 on volume. However with the resistors they went up all the way to the 45 volume level (max) I dont know about the second question, i tried looking for one too but couldnt find anything helpful :(
DavidNZ says: Aug 30, 2010. 4:40 AM
looks like night rider lol
TAKAFOOMI says: Aug 28, 2010. 11:55 AM
hi.. a few questions.. 1) would your system run off of a headphone jack of an MP3 player, split into left and right channels? 2) Do the LEDs need a power source or are they getting all their juice from the surround sound system? If it was running off an MP3 player would there be enough voltage or do you need to step it up somehow or another? 3) If you used an MP3 player, is there some sort of crossover circuit you could use to split out the bass instead of tapping into /using a full sized surround sound processor? Thanks! love your instructable!
HM-Innovations (author) in reply to TAKAFOOMIAug 28, 2010. 11:02 PM
#1 - It can, however you need to hook up your MP3 to the surround sound, if you try to run the lights straight from your MP3 player, you wont have enough juice to run all the lights. #2 - they run all their juice from the actuall Surround System #3 - you would need to run the source through an amplifier of some sort in order to make it work. :) thank you for liking our Instructable. In lay mans terms, you need to have a surround sound in order to make our lights work, i'm sure there is another way of making them work but were not sure of what exactly you need for it to work from an MP3 player =/ Hope this helped a little :)
sco_oter says: Aug 28, 2010. 9:16 AM
I'm entering something similar to this but with 300 leds and its wireless. I'm gonna put it in my truck right next to the back glass next to my subs.
HM-Innovations (author) in reply to sco_oterAug 28, 2010. 10:05 AM
That should look awesome, cant wait for the instructable good luck :) and make sure you send me the link so i can check it out! =]
mikeasaurus says: Aug 27, 2010. 8:01 PM
The second video of the light-bar in action is pretty cool. I think this instructable would benefit from resizing the small pictures and removing the advertising in the video. Try hosingt the video somewhere like youtube.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
