Step 2Step 1 Preparing the crutch
iImage Information
The first thing to do is to remove the padding from the hand grip of the crutch. This is very easy to accomplish. Simply unscrew the wing nut and pull the long screw out. Next pull the hand grip from the center of the crutch and pull the foam padding off, it should easily slide off unless your crutches are really old in which case you may need to cut it off with a sharp knife being carefull not to cut yourself. After you remove the padding you will replace the handle for stability.
