Step 5Step 4 OR Building the base
You will need to mark two lines on the base plywood (18x12). From the two farthest ends (18" apart) you will need to make a mark 3" from one end and 11" from the other. This is where you will attach the 8" x 4" blocks. These blocks will be the center supports for your crutch stand.
Put some wood glue between the blocks and nail them together with finish nails. Place the block between the two marks you made on the base plywood and center side to side. Glue down. Turn the base over being careful not to move the glued block and nail from the bottom with finish nails. (It may be necessary to wait a few moments before doing this part to let the glue set)
Add Comment
