Musical Fairy Lights
762
7
Published
Introduction: Musical Fairy Lights
About: I like to make stuff from rockets to electronics.
Welcome Everyone
It's almost the festive season and numbers of shops have started putting out their festive decorations, I thought that it’s about the right time to build some musical fairy lights!
Step 1: Parts Used
I'll be using the following:
  • 12 LED's
  • 12 Current limiting Resistors
  • 1 ULN 2803 Darlington Transistor Array
  • Some Jumper Wires
  • A piezo Speaker
  • A Breadboard and
  • an Arduino
  • To make the string of fairy lights I used 5 wires from an Ethernet cable
Step 2: The Code
//GLOBAL VARS
int barTime = 1200; // 8/8 = 1000ms byte nrLEDS = 4; // 4 Base LEDs, You can add many in parallel byte leds[] = { 3, 4, 5, 6}; byte speaker = 11; byte patternLength = 64; // pattern Length byte songLength = 51; const byte song[] = { // Jingle Bells Data 29, 2,29, 2,29, 4,29, 2,29, 2,29, 4,29, 2,32, 2,25, 3,27, 1,29, 8,30, 2,30, 2, 30, 3,30, 1,30, 2,29, 2,29, 2,29, 1,29, 1,29, 2,27, 2,27, 2,29, 2,27, 4,32, 4, 29, 2,29, 2,29, 4,29, 2,29, 2,29, 4,29, 2,32, 2,25, 3,27, 1,29, 8,30, 2,30, 2, 30, 2,30, 2,30, 2,29, 2,29, 2,29, 1,29, 1,32, 2,32, 2,30, 2,27, 2,25, 8 } ; // The Structure is Note Number then // NoteLength in 8th's const byte pattern[] = { //Pattern Data 0b0001,0b0010,0b0100,0b1000, //Bits corrispond to Leds in Array 0b0001,0b0010,0b0100,0b1000, 0b0001,0b0010,0b0100,0b1000, 0b0001,0b0010,0b0100,0b1000, 0b1000,0b1100,0b0100,0b0110, 0b0010,0b0011,0b0001,0b1001, 0b1000,0b1100,0b0100,0b0110, 0b0010,0b0011,0b0001,0b1001, 0b1010,0b0101,0b1010,0b0101, 0b1010,0b0101,0b1010,0b0101, 0b1010,0b0101,0b1010,0b0101, 0b1010,0b0101,0b1010,0b0101, 0b1100,0b0011,0b1100,0b0011, 0b1100,0b0011,0b1100,0b0011, 0b1100,0b0011,0b1100,0b0011, 0b1100,0b0011,0b1100,0b0011, };
First off I declare my variables, the interesting ones being Song and Pattern.
  • The song stores the tune; in this case it is Jingle bells.
  • The pattern stores on and off positions in the bits of the values in the array.
Custom Functions
//FUNCTIONS
int noteToHz(int note) { // Convert a Note Nr. to Frequency float freq = 440 * (pow(1.059463094359,note-21)); // -21 gives you note 1 at C3 (I Think) return int(freq); // Results are accurate to 1hz } void lightLEDs(byte PORT_X) { // Control LED's State for (int q = 0;q
The two functions I have will do the following:
  • Calculate the frequency for the tone function in the loop
  • switch on or off the LED's depending on the value passed to the function
Setup Function
void setup() { //setup OUTPUT pins
pinMode(speaker,OUTPUT); for(int t = 0; t < nrLEDS; t++){ pinMode(leds[t],OUTPUT); } }
In the setup function I set the pins required to OUTPUT.
Loop Function
void loop() {
// Music Loop for (int t = 0; t < songLength; t++) { // Notes, Length and play the melody int note = noteToHz(song[t * 2]); int length = ((song[(t * 2)+1] * barTime) / 8); tone(speaker, note, length - 50); // Flashing Lights! lightLEDs(pattern[t % patternLength]); delay(length); } // Silence Loop int randomSilence = random(1000,5000); for (int t = 0;t
I have 2 loops in the Main Loop function. A song loop and a silence loop
The song loop will read the data from the song array, play the note using the tone function
The song loop will,
  • Read the data from the song array,
  • Play the note using the tone function then
  • Light up the LED's, reading pattern array.
In the Silence loop
  • only the LED's are lit up
Plug the Arduino in and upload the code. (Then unplug it)
Step 3: Starting the Circuit
I'm going to start out with the string of lights
  • I used wire from an Ethernet cable and soldered 3 LED's in parallel four times, making sure to space out the LED's evenly over about 2 meters
  • I soldered the Anode of each led to a single wire.
  • Then the Cathode of each LED to 4 separate wires. With a resistor of course
  • I repeated this process 3 times to get a string of 12 LED's and I put header pins on the end of the 5 wires
Connect the Positive and ground rails to the breadboard
Step 4: The ULN2803
Place the ULN2308 Chip onto the breadboard
The ULN2308 is a transistor array chip; from the data sheet I can see
  • That pin 1 is an input that turns pin 18 "ON"
  • Pin 2 turns 17 on. Etc.
  • Pin 9 is ground
  • Connect Pin 9 of the chip to the ground rail
  • Connect the positive rail to a terminal strip, one strip above pin 18. (You will see why in a minute)
  • Connect pin 1 of the chip to pin 3 of the Arduino
  • 2 goes to 4
  • 3 of the chip goes to 5 and
  • 4 goes to pin 6 of the Arduino
  • Place the LED string onto the breadboard. Where the common anode wire is connected to the strip connected to 5 volts. The rest of the fairy light pins should go to pin 18, 17, 16 and 15 of the chip.
Step 5: Adding Sound
  • Connect the Piezo Speaker between 2 terminal strips
  • Connect the negative pole of the Piezo element to ground and
  • The other end of the speaker to pin 11
Step 6: Conclusion
I have a string of light's that will randomly play jingle bells to remind me that it is the festive season.
    • Planter Challenge
      Planter Challenge
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
