Step 15The PIC10F six pin processor - V3
Those wires are in a sort of colour code. Black is ground, or zero volt rail, that Microchip calls Vss. Red is positive, +5 volts, or the supply rail, that Microchip calls Vdd. Orange is the programming voltage, and the white and grey carry the Data and Clock for programming respectively.
The white wire is GP0, and the grey wire is GP1. The GP2 connection of the micro is not used, and so it is not soldered. GP1 and GP2 connect to the piezo buzzer after it has been programmed.
Since the PIC will be, in most cases, programmed once and then connected up into its circuit, I find that connecting it to the programming signals in this way is sufficiently quick. If you are trying to program it several times, for example when developing a melody, it might be better to solder it to a socket to accept the connections from your programming circuit.
Add Comment
