Well, now my dreams have been realized! In this instructable I'll show you how to go about making a pair of awesome musical shoes.
I've entered these in the Art of Sound contest, so, you know, feel free to vote for me!
Remove these ads by
Signing UpStep 1: Materials: What You'll Need
4 Force Sensitive Resistors
A lot of DIY drum pads have been made with piezoelectric transducers, but in my experience these are unreliable at best. For straight up drum pads they might work ok, but in shoes the sensors are always under a certain amount of pressure, they're not just experiencing brief impacts. Piezos are frustratingly delicate and unpredictable. They crack and bend easily, and the wires to which they are typically attached are usually pretty flimsy.
So, instead, you should use FSRs, or Force Sensitive Resistors. These components are easy-to-use, durable, and more reliable than piezos, at least in this application. Basically, the more pressure you apply to an FSR, the less resistive it becomes. Initially, it has infinite resistance, meaning it acts like a break in the circuit. I bought mine from adafruit. There are certainly other vendors, but I have no idea how and/or if they differ.
1 Pair of Shoes
Yes, this would seem to speak for itself, but there are actually a couple things to take into consideration. For my shoes I used a pair of thrift store skate shoes, the kind with a lot of padding in the heel. This is important, because you need something to conceal the jacks that you'll install in the heel. Otherwise, your shoes are going to be pretty uncomfortable. For this reason, I wouldn't recommend using thin-walled shoes like dress shoes, unless you want to add additional padding. Also, try to pick a shoe that has a rigid material on the outside of the heel, as this will make mounting the jacks much easier.
4-6 10Kohm Resistors
These are pull-down resistors that will each be connected to ground and one end of each FSR.
1 Arduino
The Arduino is an open source microcontroller - it enables communication between the FSRs and your computer. They are available from numerous vendors. If you've never done any programming before you might want to check out some of the tutorials.
1 Project Box
This will house the Arduino and serve as an interface between the shoes and computer. You can order a project box online, buy one at Radioshack, or use something you already have lying around that is more or less box-like.
8-10 1/8" Mono/Stereo Jacks
You only have two heels and two toes, but the Arduino has six analog inputs, so you might as well give yourself the option of using those at some point in the future. Four of these jacks will go in your shoes, and the other 4-6 in the project box. You can get them from Radioshack, Digi-Key, and many other places.
4-6 1/8" Mono/Stereo Cables
...for connecting the shoes to the interface. You'll find them at most electronics-type stores, like Radioshack, Best Buy, or Future Shop. I'm sure you can order them online, too.
1 USB Cable
...for connecting the Arduino to your computer.
1 Roll of Electrical Tape
...for securing the sensors in the shoes.
Mad Foot-tapping Skillz
...quantities may vary.
Visit Our Store »
Go Pro Today »
did you use serial-MIDI converter(hardware) for this project....?
Was thinking you could make kind of a dance dance revolution kind of thing using these!
Ive been wanting to put together my DIY electronic drum kit for a while,
but dont have much space in my little home studio.
And i thought of this midi shoe idea and googled it to see if it had already been done.
You beat me to the punch. :)
I have a question.
I am wondering if the shoes you have made using the FSR's can be used with conventional drum modules??
or will they only work with piezo triggers?
Thx again for a fantastic Instructables.
I have a question regarding the FSR's ( I'm currently reconstructing your idea!! ;) )
It's a bit difficult to choose the correct FSR's
If you could have a quick look here:
http://www.conrad.de/ce/de/FastSearch.html?search=fsr&initial=true&categorycode=
It would be more than appreciated if you could give me an advise which one are the correct FSR's.
From my prospective i think that the FSR's on the page mostly differentiate from there size.
Thanks alot in advance.
Fish
Thanks! I'd love to see the final product.
and make a midi shoe band.
Online Music Production School
