Musical Menorah (made With Arduino)
1,141
12
7
Published
Introduction: Musical Menorah (made With Arduino)
About: I make cool projects!
Chanukah is coming soon! So I thought it would be a great idea to make a project relating to the holiday. I made this cool Chanukah Menorah with an Arduino that plays a different song each time you change the night by pressing the button. The LEDs flicker similar to a flame on a candle. I found the songs for the Menorah by finding MIDI files of the song and using an online tool to convert it to an Arduino tone code.
Step 1: Parts/Materials
Switch to each picture to see what part it is. Hover your mouse over each object.
Step 2: Cut the LEDs
Cut 8 of the 9 LEDs about half way leaving one LED uncut. The uncut LED be the Shamash (The taller candle in the middle).
Step 3: Put the LEDs Into the Breadboard
Next, put the LEDs into the breadboard and place them equidistance from each other(every LED should have the same amount of distance between each other). I placed each LED 2 pins/holes between each other. Each side should have 4 LEDs with the Shamash (tallest LED) In the middle separating the two sides.
Step 4: Place a Short Piece of Wire Connecting Each Ground Pin to the Ground Bar
Place a short piece of wire connecting each ground pin of every LED to the Ground Bar (Usually marked in Blue).
Step 5: Connect the Ground and Positive Rails to 5v (5 Volts) and GND (Ground)
Take two wires and connect the bar marked in red to the 5v Pin and the Ground rail to the ground pin (GND) on the Arduino.
Step 6: Connect Each LED to Their Proper Pin
Connect each LED to their specific numbered pin on the Arduino. This time your connecting the LED's other pin (NOT GROUND) to the corresponding pins on the Arduino. *NOTE as you go from right to left the pin numbers decrease. The first LED (It starts on the right side) goes to pin 13 the next to pin 12, then 11, 10 ,9 8, 7, 6 and 5 should be the last pin for the last LED (All the way at the end of the left side) Your LED Menorah should look something like the last image of this step with all of the wires connected up.
Step 7: Next Place the Button on the Breadboard
Next, place the button on the breadboard making sure that one side of the pins is on one side of the breadboard while the other pins are on the other side of it.
Step 8: Connect a Resistor Up to the Button
Connect a resistor up to the lower right side of the button with the other leg of the resistor going to another column on the breadboard.
Step 9: Connect the Resistor to 5v and the Button to Ground
Take a wire (The red wire in the image) and connect it to the same column as the other side of the resistor. Connect the other side of that wire (The red wire in the image) to the 5v rail (The red one). Then take another wire (It is the black wire in the photo) and connect it to the top left side of the button and connect the other side of that wire to the ground rail (The blue one).
Step 10: Connect Button to Pin 2 on the Arduino
Now, connect a wire between the top right pin of the button (The green wire in the photo) to pin 2 on the Arduino
Step 11: Connect the Speaker
Next, connect one wire of the the speaker to pin 4 and the other to ground on the Arduino.
*NOTE if you are building this with a piezo buzzer and not a speaker, then you must take note of which wire goes to ground and which goes to pin 4.
Step 12: Time to Program the Arduino
After you completed all the previous steps your Menorah should look something similar to this.
Now to program the Arduino you must make sure you have Arduino installed on your computer.
If you don't have it you can download Arduino from their website https://www.arduino.cc/
Next download the code file Menorah2.ino from the download button bellow and open it on Arduino.
Upload the code to the Arduino and test out your Menorah!
Step 13: Conclusion
Now you can power your Musical Menorah using batteries or over a usb port.
Enjoy your new Musical Menorah
    • Planter Challenge
      Planter Challenge
    • Clocks Contest
      Clocks Contest
    • Make it Move Contest
    7 Comments
    That is posible. There are many ways to integrate electronic projects with Legos.
    Thank you so much! One of my colleagues at work is Jewish and doesn't have anything with which to decorate his desk this season. I decided I would make him a arduino menorah and, while searching for ideas, came across your instructable. I made some minor code tweaks I thought I'd share. I'm by no means an expert programmer so just my 2c.
    I added in pRNG to flicker the Shamash:
    #include "pRNG.h"
    pRNG prng;
    I made an array of the LED pins:
    const int ledPins[] = {13, 12, 11, 10, 8, 7, 6, 5};
    and streamlined the loop:
    void loop() {
    buttonState = digitalRead(buttonPin);
    byte flick1 = prng.getRndByte();
    analogWrite(9, flick1);
    if (buttonState == LOW) {
    count++;
    digitalWrite(ledPins[count-1], HIGH);
    midi(count);
    if (count == 9) {
    count = 0;
    for (int i = 0; i <= 7; i++){
    digitalWrite(ledPins[i], LOW);
    As you can tell with the song call, I combined all the songs into one midi sub and passed it the count. Within that function, I check the integer and play the required song.
    I'll try to post a pic of my finished design after this weekend. It's just breadboarded right now. I'm also hoping to migrate to a smaller chip to save my Uno, haha.
    YOU SAVED ME HOURS ON THOSE MIDIS!
    True i didn't think about that lol.
