3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Musket Paintball
Musket Paintball
  • last photo ←
A friend and I were talking about picking up paintball as a hobby. We got to talking about it and we got the idea of Musket Paintball for two main reasons. One, we didn't have money. Two, we thought it would be more challenging to modify the rules of paintball a bit.
The core of the idea is to make your own paintball gun for cheap. We also didn't want to be spending money on refilling CO2 canisters. Again with the cheap.
The first part of this instructable is how to build a spud gun style paintball musket. If you're familiar with a spud gun or have already built one, this will be simple for you. There are only a few simple changes to make for paintball.
We did try compressed air but it didn't have the range we wanted. However we were only trying at +/- 100 psi. Some portable compressors say they can go to 300 psi which might work much better.
This isn't an absolutely unique idea obviously. There are others that have done similar projects.
http://www.instructables.com/id/Areosol-powered-paintball-gun-in-action/
http://www.instructables.com/id/paintball-air-cannon/
http://www.instructables.com/id/homemade-paintball-gun/
The main idea is to convey how to and then introduce the idea of a different class of paintball contest.
Step 1Materials
Materials
The main idea here is to make a spud gun that will take a paintball. The design of this gun is to make loading the paintball and propellent easier.
These are the parts that have important dimensions.
3/4 inch CPVC pipe <- this is the barrel
2 inch PVC pipe <- this is the combustion chamber
1 1/2 inch cleanout adaptor
1 1/2 inch threaded adaptor to screw into the cleanout
2 inch end cap
The other parts that are variable based on availability. This is what I used.
1/2 inch to 3/4 inch adaptor
3/4 inch to 1 1/4 inch adaptor
1 1/4 inch to 1 1/2 inch threaded adaptor <- this is an odd part and may not be available
Other important parts
pushbutton grill lighter
2 short (1-1 1/2 inch) screws
PVC cement
Paintballs
Tools
Saw for cutting PVC
A drill
A screwdriver that works with your screws
17 comments
Aug 26, 2010. 8:42 AMmabster says:
is there a video?
Aug 26, 2010. 10:33 AMmabster says:
the firing
Jul 17, 2010. 1:14 AMlemminggenocide says:
also, if you're looking for a high pressure hand pump, get a shock pump. They're used for suspension forks on bikes, and are made with a one way valve that can go up to 400 psi. They will attach to schrader (bike tyre) valves.
Jul 17, 2010. 1:12 AMlemminggenocide says:
Piston valves are more effective for smaller calibres, and can be actuated with a ball valve. Hammer valves will give you multi shot capability, like this one http://www.spudfiles.com/forums/paintball-hammer-valve-prototype-t14690.html hammer valves are fairly simple to construct too. http://www.spudfiles.com/forums/hammer-valve-now-with-vid-t17843.html I'd say a hammer valve would be easier than modding a sprinkler valve.
Jul 11, 2010. 8:16 PMsamdaman says:
well i've never made anything like this before and i have always wanted to. i have come up with about 20 trillion different ideas ranging from basic pvc ball valve guns to semi automatic magazine fed paintball snipers with a realistic looking wooden body over the pvc. i will try a ball valve before a sprinkler valve just so i know what im doing
Jul 11, 2010. 8:00 PMsamdaman says:
so do you think i could just build a basic paintball air rifle ( oxygen chamber filled up by use of a bike pump) and it would work as a good paintball gun just as a beginner project? it would of course be muzzle loaded and use a ball valve
Jul 11, 2010. 7:48 PMsamdaman says:
ok thanks. also do you think it would be possible to make a bolt action type paintball sniper that you hand load into where you pull the bolt back. it may be sort of like a breech loading sniper.
Jul 11, 2010. 5:22 PMsamdaman says:
i come from new zealand and the sizing of the pvc is done in mm. if i were to build one would it be good to use 20mm pvc pipe which leves 1.5mm extra on each side because paintballs (.68) are 17mm diameter? the smaller size is 15mm which wouldnt work and i cant find any odd sizes
Jul 6, 2010. 12:06 PMtomtortoise says:
what caliber paint balls did you use .43?
Jul 6, 2010. 3:11 PMtomtortoise says:
and those are the right size or are they snug like do they have any room to slide?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:EmmettO(Store32)
EmmettO is a general mad scientist, blacksmith, metalcaster and former Unix admin. Now he fixes darn near anything that people throw at him and breaks things that need to be broken.
