3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Muslin Photography Background
Step 7USE IT !!
USE IT !!
After it was dry I took 4 binder clips and clamped them evenly acrooss the top of the fabric. I 'm going to put little white hook-screws in the wall to hook through the holes in the binder clips but for the photo below I just used clear package tape to hang by the clips (be carefull when removing tape, the paint may come with it!).
This is somthing you can do *really* easy takedowns and setups with and you can use any wall in your house and there is no need for a "blank wall". This is in front of my closet.
When its not up, leave it balled up in a corner somware so you dont loose all the cool wrinkely texture.
I hope you ernjoyed reading this and it helps you out. Now make your own!
5 comments
Apr 6, 2011. 7:20 PMakbly1 says:
Hi!
I stumbled across your DIY photography website as I was searching for cheap backgrounds. I am an ameteur photographer and enjoy taking our family photos as a hobby. I also enjoy DIY projects so was excited to give the backdrop a try. I followed your instructions and the first one I made was more or less trial and error. (I ended up spray painting over it later to create a marbled effect). The second one I did in cocoa brown and dark brown turned out much better. Thanks so much for the great tutorial and for sharing your talented ideas and creativity!
Apr 20, 2007. 9:59 AMLSRPhoto says:
Wow, Thats pretty cool, I was thinking about doing somthing similar, but I have had the guts. I think you convinced me. I went to college for Photography and they were always thinking of "inovative" cheaper ways to do things. We used a PVC Pipe and drilled holes 1/2 way through about an inch from the ends. We then put this over two stand. This mad a nice middle support Piece for a background. We got a smaller diameter pole, but thicker plastic so it wouldnt sag to bad. Good job man!
Mar 25, 2008. 7:13 PMfredso says:
I once made an entire convention backdrop out of PVC and cheap dropcloth. You can put the whole thing together using the PVC pipe, t-fittings and/or elbow joints available in the plumbing section (like and erector set). No glue, easy to break down (all my sections were 4 feet so as to fit in the car). Admittedly, you have to get creative with the base, but it's somewhat cheap and quick to set-up and breakdown.
Feb 23, 2008. 11:51 PMhumphrey7 says:
This is exactly what I was looking for. The binder clips are a great idea! What color dye did you use on the one in the photo?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:camscam
25/m
