loading
Following on from my last instructable https://www.instructables.com/id/A-Simple-Customisable-Card-Game/ I'd thought I'd post a second game that was developed at the same time.
Whilst this could probably feature in the Dad-Can-Do challenge, I'm not entering it. Mainly because it would be the second entry from me and this game is not as "family friendly" as the other one.
Any questions, clarifications or improvements, please lease a comment!
This game - MuzzleFlash - has undergone extensive play testing with multiple people and groups and I believe is a stable, fun and competative game.
Now a short bit about the game!
MuzzleFlash
A unique customisable card game simulating a "deathmatch" style multiplayer computer game. CTF (Capture the Flag) and Team CTF are also possible.
Number of players: 2 to 10 (play tested to 6, but should work fine with bigger numbers)
Time to play: Last Man Standing Deathmatch - 2 players - 10-20 minutes
Step 1: Explanation of the Cards
The cards consist of several items. Power, Defence, Cost, A Picture and text.
Power - The ammount of damage a weapon can do
Defence - How much damage Armour can take.
Cost - The value of the card (used in determining deck total)
Picture - Visual representation of the item
Text - Explains any extra effects or rules of the item.
Cover Value - a Numeric representation of the cover
Step 2: Personality Cards
These are special cards and represent you (your character) in the game. There
is a space to write your name on the card and a space for a photo or sketch.
Personality cards have two weapons printed on them. One ranged and one close combat.
These are your default weapons, they cannont be discarded or lost.
Step 3: Deck Construction
A deck may consist of a maximum of 60 points and a maximum of 41 cards, including one personality card.
a deck can have any mix of weapons, armour, actions and special actions.
A good deck will have a selection of Cover cards, Armour, extra weapons (double up on your Default weapons for dual wielding goodness!) and essentially move cards. Customise the deck to your style of play (and to counter your opponents!)
Step 4: Initial Setup
1. Separate the Personality card from the rest of your deck.
2. Shuffle all of the remaning cards.
3. Place your personality card as shown in the diagram.
4. Draw four cards, and discard one to the discard pile.
5. Lay any Weapon, Armour or Cover Cards that you wish to use.
6. Determine who will start (Roll a die / toss a coin)
7. Each player has a starting life score of 20 (use counters or a d20 to track your life points).
Step 5: Play Procedure
1. On every turn you MUST draw a card (even on turn 1).
2. Lay any Armour, Weapon or Cover cards that you want.
3. Determine if you are attacking or not.
4. Determine if you will use a special action card this turn (Spray, Rapid Fire, Med-Kit etc.)
5. Lay any Armour, Weapon or Cover cards that you want (if you can).
6. End Turn
If during play, you run out of cards, remove the top card from the discard pile, shuffle the remaining cards and place it in the deck pile and replace thensingle card on the discard pile.
Step 6: Attacking and Defending
If you are attacking there are two steps to follow.
first is the removal of cover (if any), then the actual striking of the target.
If opponent has a cover card in play.
1. Announce which weapon(s) you are using for your attack.
2. Add the COST of the top card of your DISCARD pile AND your opponents DISCARD pile together. if this value is greater than the cover value of your opponents cover card, then you have sucessfully avoided the cover, and your opponent discards the cover card.
3. Add the power of your weapon(s) and the cost of your opponents top card on his DISCARD pile together for the total shot power.
4. Subtract from the total shot power the defence value of your opponents personality and any armour cards (s)he may have in play.
5. At this point in time, your opponent may play up to one MOVE card and one ACTION card (Dodge, Duck or Jump) to try and absorb additional damage.
6. Any aditional power points not absorbed are taken as damage, and are subtracted from your opponents health.
Step 7: Attack and Defend Example
Player 1 attacks Player 2. Player 2 has a Car in play (cover value 5).
Player 1 adds the value of his top card on his discard pile (a Move card - Cost 0), to his opponents (an M-16 - Cost 8). the Total is greater than 5, so the shot misses the car, and hits player 2. Player 2 now discards the Car card.
Player 1 adds the power of his standard weapon printed on the personality card (a Beretta - power 2) to the cost of the top card of his opponents discard pile (the Car card just discarded - Cost 6). Total damage is 8.
Player 2 has a natural defence (printed on his personality card) of 3. He is also wearing a Leather Trench Coat (defence 1). Total is 4.
Therefore Player 2 take a total of 4 points of damage. Player 2 also has to discard his Leather Trench Coat, as it has a hole in it!!
If a player has no cover card in play, then, ommit step two in the attack and defence sequence.
Phew!
It may seem complicated, but once you understand it, it's a very quick game mechanic (and no rolling of dice or other complicated stuff)
Step 8: Expanding Play
The game can be expanded to many individuals with no change in rules. There
are a few cards that can deal with many opponents (e.g. Spray) and you may want to include them if you are playing with more than two players!
Team Deathmatch is also possible with this set up.
Capture the Flag & Team Capture the Flag
Included in the card set, there are Base and Flag cards. Add 2 of each to each deck. A player must play a Flag card BEFORE playing a base card. If the Player dies while carrying the flag, then the flag is discarded. Play until a pre-determined number of flags have been captured. Only one flag can be in play at a time per team or individual.
Step 9: Without Further Ado!
And without further Ado, I give you the cards!
The cards are sized to print on A4 and on Letter sized card. if you are having trouble with getting the "right kind" of card, print on paper and stick to a cheap deck of playing cards.
This set should be enough to create 2 decks in a single printout if you print them all.
Step 10: Further Expansions and Disclaimers
I will hopefully expand this game to include more weapons, personality cards and more multiplayer cards and more cover types.
It should also be possible to create themes for different settings other than just an urban one.
There are some images missing, namely the cover cards, when I find the relevant images, I will re-upload these images.
Disclaimer:
None of these names are used with any licence or anything else. All trademarks and names belong to their respective owners. If any of the copyright/trademark owners have a problem with me using the names and images, I urge them to contact me.
There's no explanation of move cards...
Hello,<br><br>The move card is like the &quot;duck&quot; or &quot;dodge&quot; cards, but have no points value.<br><br>The only caveat is, that if you play a move card behind cover, you must either move to a new piece of cover or into the open.<br><br>you can stack your deck with as many move cards as you like - but remember, the more move cards, the lower your odds of drawing something useful.<br><br>Hope that makes sense
But what do duck and dodge DO? I need a game mechanic explanation.
Duck and Dodge are an action that temporarily increases your defence stats for that turn.<br><br>If your defence is high enough you take or reduce the damage that would otherwise be dealt.<br><br>Move does not have a points value to it, but duck and dodge do.<br><br>Duck and Dodge can be used to &quot;fill&quot; out the points requirements of the deck while providing some sort of reactive defence.<br><br>I hope that explains it :)
I really think you should go back and give an in-depth explanation of the cards in the rules stated in the instructable. Possibly even going back and explaining all the other bits just a little more, since your explanations are short and quick. I understand the attacking and defending section just fine, but the rest is a little lacking.
yes, I agree, I'll add in a section covering the cards.<br><br>When I built this game, I always intended to put more information directly on the cards so as to keep &quot;mental rules&quot; to a minimum<br><br>this is something I will have to do as soon as I get some time away from my job!<br><br>I hope you enjoy playing the game - if you need any clarifications on anything please post another comment!
What works great as card if you just print it on paper is those big pices of poaster stuff that is paper thin but is still hard. :( dont know what its called
Poster board?
About This Instructable
2,421views
10favorites
License:
More by undescriptive:BrutalBall : A future sports customisable card game MuzzleFlash : An expandable customisable card game. Dragon Tournament Fighter : A Simple Customisable Card Game
Add instructable to:
