My 30$ Milling Machine by narpas
Here is a 3 axis milling machine I made! It was inspired by tom's Cnc milling machine Instructable but I kind of took it a whole new way. This thing is awesome you can make circuit boards and engrave your name! I recently broke a part so I have to fix something on the bottom rails. www.jamstudiosgames.com
lev22 says: Jan 9, 2012. 5:26 PM
i really like the idea of the hand crank idea but i have a few questions .
how did u get the sliding rails through the wood ?
will it cut light metals?
thanks
mycroftxxx says: Mar 31, 2009. 10:07 PM
where are the motors, and what kind of controller are you using?
cotton says: Dec 31, 2009. 7:18 PM
 hand crank DUH
dchall8 says: Apr 1, 2009. 1:07 PM
The only motor looks to be inside the red housing turning the tool. The screws have hand cranks.
thrhymes says: Mar 31, 2009. 10:47 PM
not every milling machine is a cnc milling machine....
rimar2000 says: Apr 1, 2009. 5:08 AM
It is nice, is similar to my "getto lathe" in construction, except that mine is on iron. I intend to do an instructable when it is completed, which, with luck, will be this year.
sharlston says: Jul 30, 2009. 2:07 PM
wow ill be looking forward to that please inform me when you make it
rimar2000 says: Aug 2, 2009. 2:45 PM
rimar2000 says: Jul 30, 2009. 5:52 PM
The lathe is almost finished, only lacks accesories. It was possible owing to an "sanitary license" for the H1N1 flu. I will do the instructable in 1 o 2 weeks.
Bongmaster says: Apr 1, 2009. 1:47 PM
nice :) i started a ghetto lathe type instructable a while back but it hasnt got verry far :)
rimar2000 says: Aug 2, 2009. 2:46 PM
Bongmaster says: Aug 3, 2009. 1:36 PM
i saw that XD
Bongmaster says: Apr 1, 2009. 1:48 PM
so u making a build instructable on this? :)
narpas (author) says: Apr 1, 2009. 3:37 PM
Do you think I should?
sharlston says: Jul 30, 2009. 2:06 PM
yes definetly
vernonstien says: Apr 11, 2009. 7:37 PM
Yes, Also you may be able to enhance it by adding a tracer to it. As it is, it's like you have to ectch-o-sketch parts which is fine if your good at that. I'm not, so I have to have something to trace. Still a pretty cool tool to build, looks so easy, even a caveman could do it,..... I think I will.
narpas (author) says: Apr 19, 2009. 12:14 PM
I dont think I will have an instructable on this for a while I have several others I want to work on!
christophor says: Apr 14, 2009. 8:57 AM
Great job. It's nice and simple. Very clever. You should post an Instructable about this. I think a lot of people would get something out of it.
Tom McGuire says: Apr 3, 2009. 8:21 PM
Hey Cool... Nice Job. Do you have a picture of something you made with it? Tom P.S. Thanks for the plug. :)
microman171 says: Mar 31, 2009. 10:59 PM
Instruction Please =)
I like the use of no motors, you don't see that every day.
Is there a way you can measure? You could put a pointer down and have that against two rulers?
narpas (author) says: Apr 1, 2009. 3:36 PM
I could but usually I just lay out the part with pencil and then cut it out
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
