http://www.instructables.com/id/The-Word-Clock-Arduino-version/
also inspired by
http://www.highonsolder.com/blog/2011/1/8/arduino-word-clock.html
http://www.instructables.com/id/Sleek-word-clock/
Remove these ads by
Signing UpStep 1The Materials
Is there a chance to make an Arabic version?
I have 24 separate words to play with, so it should be doable.
Doug
http://qlocktwo.com/
Regards
Is it easy to modify the program to control the led sequence?
Try to contact if you want this author
is very kind and competent, may have already done something in Arabic.
Regards
Thanks for helping
"I paid several euros to have the designs and build the pcb" - The text on the instructable wasn't clearly mentioning that. "Has made by a professional mastering" gives more of an idea that you are a professional in designing PCBs. Sorry about that again.
" mine is just a request for transport cost" - I thought that you would email a soft copy of the design or upload it here. Sorry again, misunderstanding.
"but as youI've seen i have completely shared project including wiring diagrams" - I completely agree, and honestly, following your schematics and design ideas, I'm building my own word clock! Thanks to Doug as well!
"If you have nothing to do go to to make the communist from another site please." - I dont understand this statement, please elaborate.
Over everything, this is a very nice instructable. Hats off to you. :)
'Author:Cello62
There is no joy in possession without sharing'
And yet -
'I can send gerber file for a small fee.'
Anyhow, I wonder how much.
You don't have understood my words. I've just wrote that there is another member, Doug Jackson, that has made a word clock using Ds1302.
Look at http://www.instructables.com/id/The-Wordclock-Grew-Up/.
Regards
Do I just completely ignore it and imagine it isn't there?
Yes you have to ignore this part (CN1)
Me too i didn't use the Arduino but only the ATMEGA and of course what it takes to make it work. View photos of the card and you'll see that I put only the chip. The card is designed to connect directly to an Arduino (CN1) connecting the various pins but it is a choice. In this case you don't need C1-C2-X1-R1 because are already included in the Arduino. Greetings
If I'm mistaken, what else gets connected to these pins other than the microcontroller?
What do you mean by I don't need C1-C2-X1-R1? Isn't the point having them so I can build the arduino on the card itself?
Also, I'm not very good with arduinos, but can I program the microcontroller on an arduino UNO, then take out the chip and just place it on the card?
Thanks again!
-if you use a board like the one i did, with a ATMega standalone, you need c1-c2 and so on, better you need capacitors, clock, resistor, all that is indicated by my scheme ok? If you plan to connect an Arduino to my board it is no necessary to add these component because are already included in an typical Arduino board, if you plan to build another board with an Atmega standalone to connect to my board you need all these component (and others like power supply and so on) but in your board to drive the Atmega ok? The last method is a no sense because is more simple to add an Atmega to my board.
For the second question YES, i have done this, i've buyed an Atmega 328 with bootloader inside, replaced with that of Arduino UNO, reprogrammed and placed on my board.
Regards
http://www.arduino.cc/en/Tutorial/ShiftOut
Thanks for your comment
Regards
Thanks for comment
I ve done a little description in each photo step because , as you read, I was inspired by existing designs, especially in Sleek word clock, I will be happy to explain to you what you want
