3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
My Awesome Led Cube.......................
Well as the name suggests this is my awesome led cube, its made of acetate sheets (translucent) and the a Pepsi can, with a multicoloured led circuit I harvested? from cheap pen thing. I custom designed the 6th side of the cube to match the previous 5 and also to hold the initials of my split personality(Lord Hades) so here it is.............................
44 comments
1-40 of 44next »
Jul 6, 2009. 4:09 PMsquirrelMLM says:
I GOT AN IDEA! how bout we make a whole bunch of these, and make them into a rubiks cube? impossible but that would be a very super special awesomely mega chocolate fudge coated idea!!
Jul 5, 2011. 10:47 AMvishalapr says:
I might actually try and make one! with different colors on each side
Jun 4, 2011. 8:34 AMkarlpinturr says:
Turning 26(?) of these into a Rubik's Cube shouldn,t be too tricky - providing you can scale the Cube's mechanism up sufficiently...
Scaling these down to fit a Rubik's Cube mechanism would be rather more so...
Having the resultant Cube light/not light up in specific ways, depending on the combinations may well be nigh-on impossible... ;-)
Jun 5, 2011. 5:44 PMsquirrelMLM says:
Funny how you guys reply almost two years later. Because the Rubiks cube company(?) has made a light up touch screen rubiks cube since then :D
Jun 5, 2011. 4:49 PMfacilitator476 says:
Why scale them down, it would be much cooler to make a giant, glowing rubiks cube
Jun 6, 2011. 1:10 AMkarlpinturr says:
Cooler, yes...
but so much more challenging to scale them down as well... ^_^
Oct 9, 2010. 6:58 AMacornman says:
There is probably no need to waste hot glue to create translucent effect,merely rub the inside surface of the acetate (perspex) with an abrasive sheet and you will "frost " up the box. For simple colour changing use a rainbow LED these are self contained led's with colour change built in (they need 4.5 volts though - so use 3 X 1.5 button cells). Great little projects like this can spark off many ideas,so well done.
Aug 20, 2008. 3:09 PMKiteman says:
How is it controlled? Does it sense contact on the metal, or does it just cycle through the colours? Where is the on-off switch?
Jan 14, 2010. 8:25 PMEvidenceremoved says:
If that was a question, then you can get the batery on one side, and the other end of the wire 1cm away, then when touching a conductive metal, it would comp[lete the circuit, and light the LED. When you moved it away from the conductive metal, it would stop.
May 14, 2010. 12:06 PMexcaza says:
Reed switch :)
Jan 7, 2010. 5:48 PMfootball01 says:
realy cool but iv seen better
Nov 14, 2009. 9:00 AMAnitaCHawk says:
I really like how yours look compared to the others I've seen. It looks really "neat" (literally).
Sep 8, 2009. 1:01 PMZOOBREAK says:
show us how to make it
Aug 18, 2009. 2:03 PMTarzanJr says:
I GOT AN IDEA! how bout we make a whole bunch of these, and make them into a rubiks cube? impossible but that would be a very super special awesomely mega chocolate fudge coated idea!! SquirrelMLM that is a GENIUS IDEA
Aug 21, 2008. 8:38 AMcyrozap says:
looks like the allspark... (go watch Transformers)
Jun 3, 2009. 5:43 PMchosenangelx says:
alex's idea was based on transformers allspark, i asked him T_T
Jun 2, 2009. 6:16 PMredsoxrock97 says:
Yeah your right. i've seen like 5 LED cubes. i just wish i could actually make this stuff. my parents are kinda strict, so if i was buying LED's and translucent acetate sheets they wouldn't let me even think about making these. =(
May 26, 2009. 6:39 AMBraisedDuck says:
looks like the LED cube is quite famous right now.......
May 25, 2009. 9:13 AMEccentric1 says:
What did you use to cut the soda can? The edges to the armor pieces look very straight, and look like they lay very close to the surface of the cube.
May 16, 2009. 9:04 AMS4mmy says:
Looks like a Tri-Colour LED to me :D
May 1, 2009. 5:48 AMepraekelt95 says:
It's a great and interesting instructable. I'm gonna try and make one, but bigger. Looks real cool!
Apr 24, 2009. 7:26 PMiTraceur says:
Just curiousity, where did you get the name Lord Hades from? Because my friend uses the exact same name... Hmm...
Apr 19, 2009. 2:53 PMTimothy.Mehlhorn says:
how much hot glue did you use? (Did you just cover the acetate or did you fill the entire thing with hot glue?)
Mar 5, 2009. 7:30 PMi_build_stuff says:
i like the initials idea i might try to do that with mine as soon as i find a cheaper place to buy my rgb led
Feb 1, 2009. 1:37 PMBridel568 says:
how did you make it with the different colors? that could make a good Instructable
Nov 17, 2008. 11:24 PMduck-lemon says:
did u use the template on the instructable 'cos i made it and it looks kinda the same?
Sep 26, 2008. 8:24 PMtwist2b says:
Is that seriously ONLY soda can covering? Thats cool. I want the light!!!!!!! Oh and were did you buy the acetate sheets?
Aug 23, 2008. 12:40 PMn8man says:
Nice, but I think it would look better in the dark than in the light
Aug 22, 2008. 1:04 AMtreg says:
mmm, the result is awesome for the small amount of work. But i like the design very very much, why don't some spent the taime to make a mold to make the metal part out of lead, 1/4" wide, the put some semi(translucent silicon in the gap between the different isle of lead ? that surely would we amazing. I don't have what I need to mold lead, but maybe I can try doing it out of cement... got to try ! (oups, no time to try if now :(, please someone do it !
Aug 22, 2008. 6:44 AMtreg says:
ok, lead was just an indea, but making a mold from scrap wood and carving the wood to make the drawings on the cube, then making the cube with cement is certainly possible in most part of the word. No the last probleme would be to find something else than silicon which can be put in the drawings on the cube... Maybe some bee wax or any synthétic imitation may suit. maybe some (hot ?) glue can also do the trick. Polyurethan / epoxy resin would certainly work well also (though might not be aviable or affodable to some). It might be possible to paint the cement before the wax / glue / resin is added in the gaps, and to includ some craps things (struts, metal wire, ...) in it. I like this design, and I'd like two see what can be done by spending 10 hours of work on the making :) Anyway, I really like the (simple) idea of doing it with soda can. Amazinf how many things can be done with soda cans :)
1-40 of 44next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:blckthng
