My Batch Files
Published
Introduction: My Batch Files
My program is called Keylock. You simply choose your 'key' and it writes a file onto it. then once you exit and re-open without the key in, it will say 'Please insert your key.' until you put your key in.
Main.bat:
@echo off
if exist "Config.bat" goto Skip
set /p Path=Enter a key path.
set /a Num=%random%*1000/32768+1
echo set Path=%Path%>"Config.bat"
echo set Num=%Num%>>"Config.bat"
cls
echo Please insert your key.
echo.
echo ^(Press a key^)
pause>nul
if exist "%Path%" echo Key>"%Path%%Num%.key"
:Skip
call "Config.bat"
call "KeyLoop.bat"
title Menu
:Menu
cls
echo
Menu
echo ----
echo.
echo 1. Begin
echo.
echo 2. Change Key echo.
echo.
set /p ans=Choice:
if %Ans%==1 goto Begin
if %Ans%==2 (
call "Config.bat"
call "KeyLoop.bat"
del "%Path%%Num%.key"
del "Config.bat"
cls
echo Restart to create a new key.
echo.
pause>nul
exit
goto Menu
:Begin
::Your code here
KeyLoop.bat:
cls
title Locked
:KeyLoop
if not exist "%Path%%Num%.key" goto KeyLoop
To Use:
Open Main.bat.
Enter the directory the key will be stored in.
If that folder does not exist create it. e.g. Put in a USB stick.
Put your protected code where it says ::Your code here.
    • Planter Challenge
      Planter Challenge
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    5 Comments
    loops like that cause lag, you should think about adding a "sleep" in there somewhere
    If you know batch code or want to protect a batch game you have, you put that code where it says ::Your code here. Then you cannot run that code without inserting your key.
    i still dont get what you use it too and with what program ?
    All code where it says ::Your code here will not run unless a certain key is detected.
