(Skip ahead to the next step if you want to use files that already made) Things exist on the internet for free sometimes. The heart used in this tuto...
There is a JPEG attached that will print two hearts and a border on one transparency sheet. This is useful if you have two valentines. See below for ...
I've included a file with some words. You may want to personalize this experience for that special someone. Do whatever you want. Remember that you'r...
Be careful. Follow the border on the original heart print. Leave some red if you'd like. You can tape the edge to preserve the words and the origina...
The ink may dry a little bit, but it will likely never dry completely. If you tape or glue the corners it may help preserve your prints. Since you ma...
Hi! I never used glue, but found the ink was sticky and would hold my two sheets together. A little dab of clear glue in the corner could make them a bit stronger, not a bad idea at all...
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
but how do i paste the two printed sheets..?
did u use super glue or pvc glue..
