3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
My Electric Stick Bass (but with a G-string)
I made an electric stick bass using instructions from two instructables-The electric stick bass, and the altoids tin guitar.I used elements from both and came up with a plan for this.It's does the same as the electric stick bass but is alot higher, and has a cut-of switch (toggle on-off) and a cut-of switch that is momentary (normally closed) that is used to 'stutter' the sound in and out.
4 comments
Feb 27, 2009. 12:16 PMlemonie says:
I made something very similar with the coil from a headphone speaker, worked like a real pickup. I'm slightly surprised that it works with a piezo, but I can believe it. L
Mar 16, 2009. 12:00 AMst.paul says:
if you set something to use as a bridge (i used a bolt) on the goldish face part and run the string over the bridge over the piezo, it'll blast. and if you still dont have a deep enough sting, then try a (thickish) piece of nylon weed eater string, mine's tuned to bass D.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:tudgeanator
